Re: Yes, 3D printers can go on fire. January 15, 2014 07:36PM |
Re: Yes, 3D printers can go on fire. January 15, 2014 07:48PM |
Ohmarinus
I just think it's incredibly dumb to let your wires run loose like that. Lesson learned I guess? A good lesson is a lesson where nobody got REALLY in trouble.
I hope you manage to repair the machine Lucky guy!
Re: Yes, 3D printers can go on fire. January 15, 2014 07:51PM |
brnrd
I think one way to route the wires safely to the carriage is to run the wires through a spring as was done in the Ord Bod. This would keep the wires from drooping down, and it would have avoided the problem that you encountered. I found that a plastic spiral wrap which I'm using now also works, but maybe not as good as a spring.
Re: Yes, 3D printers can go on fire. January 15, 2014 07:56PM |
bytemedwb
Wow - I have always worried about this possibility. I have the wooden Makerfarm also. So I just went on to
amazon and bought:Flame Defender - 12 KG - 7.7' coverage
[www.amazon.com]
I don't worry as much about the type of short OP had but more the idea that the thermistor fails
and a run away hot end ignites plastic. Add to that the can of Acetone that is generally there.
Re: Yes, 3D printers can go on fire. January 16, 2014 03:02AM |
That's a great idea. There's no reason for the temperature to drop more than 10-20C whithin a printjob (except g code temperature changes). If this happens, the firmware could initiate an emergency shutdown after 5 seconds or so.Quote
dave3d
I also think the thermistor should have a failsafe in the firmware to guard against it being dislodged.
Re: Yes, 3D printers can go on fire. January 16, 2014 03:41AM |
Re: Yes, 3D printers can go on fire. January 16, 2014 03:50AM |
Admin Registered: 11 years ago Posts: 3,096 |
Antslake
bytemedwb
[www.amazon.com]
I like this!
For the rest of you, If I wasn't clear, my wires were tied up. They are only untied in the photo after the fact. I wanted to see which ones got burned. I just positioned them in the spot again so you could kind of see what happened. I had wire ties, shrink wrap, and zip ties holding it all very neatly with the minimum amount require for full travel. So don't think you are safe or smarter than me because your wires are tied up!
Re: Yes, 3D printers can go on fire. January 16, 2014 04:18AM |
Re: Yes, 3D printers can go on fire. January 16, 2014 04:45AM |
Admin Registered: 12 years ago Posts: 2,569 |
Re: Yes, 3D printers can go on fire. January 16, 2014 10:12AM |
Re: Yes, 3D printers can go on fire. January 16, 2014 10:33AM |
umdpru
correct me if I am wrong but Marlin uses the Min_temp setting in that exact case. You need to set it to the right temperature though. The default value is 5C. It should be much closer to your hotend working temperature, though. the thermistor will rapidly detect a decrease in heat, though, if it were dislodged. When the min_temp threshold is breached, the controller goes into failsafe and shuts down the hotend. This also protects against thermistor wiring shorts.
This kind of failsafe wouldn't have helped in this case, though, because the stepper wiring got shorted. I'd be curious to know why the Ramps fuses didn't open. There are two for the DC inputs, afterall.
Re: Yes, 3D printers can go on fire. January 16, 2014 10:57AM |
Antslake
I am definitely building a metal enclosure for the RAMPS. Think about it, any UL listed device that has that kind of power going through it is in an enclosure. I wonder if these are even UL listed.
Re: Yes, 3D printers can go on fire. January 16, 2014 01:37PM |
Re: Yes, 3D printers can go on fire. January 16, 2014 02:08PM |
Re: Yes, 3D printers can go on fire. January 16, 2014 02:14PM |
umdpru
Re: Yes, 3D printers can go on fire. January 16, 2014 03:01PM |
Re: Yes, 3D printers can go on fire. January 16, 2014 03:27PM |
umdpru
The overtemp limiters on the chips are for the chips, they aren't there to prevent motor wiring shorts causing fires. I think I will be adding inline fuses to the 11A and 5A lines as a start.
Re: Yes, 3D printers can go on fire. January 16, 2014 06:05PM |
Antslake
I was using industrial heat shrink over the exposed length. I would like to see a pic.
Re: Yes, 3D printers can go on fire. January 16, 2014 07:58PM |
brnrd
Antslake
This is not true. I can think of many household items that use much more power (kw or more) that are in plastic: electric drills, blow dryers for hair, iron for clothes, waffle makers. Typical 3D printers use 20 A at 12 V with 1 extruders. That's only 240 watts.
Re: Yes, 3D printers can go on fire. January 16, 2014 08:00PM |
tjb1
Instead of hanging your wires from the top, attach them to one of the carriages that the Z screws go through. That way height changes don't change the length of cable going to the extruder carriage and you just need enough for the X travel.
Re: Yes, 3D printers can go on fire. January 16, 2014 09:54PM |
Antslake
brnrd
Antslake
mmm, let's see. An electric drill has a motor in it that is enclosed in metal, blow dryer also has a metal shield around the heat coils, and a metal motor, and iron is metal, waffle makers are metal......yep, going with metal.
Think about our power supplies themselves, or PC power supplies with FETs, they have metal enclosures. FET's are known to burst into flames. They actually shoot flames out like a jet engine.
Re: Yes, 3D printers can go on fire. January 16, 2014 10:01PM |
bobc
Stupid question, but if mintemp is set to 210, how does the heater ever turn on?
Re: Yes, 3D printers can go on fire. January 16, 2014 11:08PM |
CraigRK
bobc
Not so stupid. It is the one thing that I have been wondering about. A number of people have been talking about this, but none of them seem to really know how this feature works in the firmware.
On my machine this is set to 5C and it means that in winter I can't get my printer (which lives in the garage) to even start printing unless I use a hot air gun to warm up the hot end first...
Re: Yes, 3D printers can go on fire. January 16, 2014 11:16PM |
brnrd
I'm not saying that metal is not better. My point is that UL listed devices don't have to be in metal enclosures.
Re: Yes, 3D printers can go on fire. January 16, 2014 11:36PM |
Re: Yes, 3D printers can go on fire. January 17, 2014 12:33AM |
Re: Yes, 3D printers can go on fire. January 17, 2014 01:17AM |
Yvan
CraigRK
bobc
So we need to be able to set in the firmware some kind of temperature range that is only used while the hot end is heating up or maintaining a set temp. If it drops out of that range, things need to stop...
If I understand correctly.
Re: Yes, 3D printers can go on fire. January 17, 2014 04:27AM |
Re: Yes, 3D printers can go on fire. January 17, 2014 06:49AM |
CraigRK
bobc
Re: Yes, 3D printers can go on fire. January 17, 2014 07:17AM |
