Re: Yes, 3D printers can go on fire. January 29, 2014 07:32PM |
Re: Yes, 3D printers can go on fire. January 30, 2014 08:49AM |
Re: Yes, 3D printers can go on fire. January 30, 2014 01:41PM |
Admin Registered: 15 years ago Posts: 2,569 |
Re: Yes, 3D printers can go on fire. January 30, 2014 02:49PM |
DeuxVis wrote:
I might be dumb, but I don't see the interest in shutting down the power of the printer once it has already catch fire ?
Re: Yes, 3D printers can go on fire. January 30, 2014 03:13PM |
DeuxVis
Re: Yes, 3D printers can go on fire. January 30, 2014 03:36PM |
Re: Yes, 3D printers can go on fire. January 30, 2014 07:17PM |
Re: Yes, 3D printers can go on fire. January 30, 2014 08:12PM |
Re: Yes, 3D printers can go on fire. January 31, 2014 05:56AM |
Re: Yes, 3D printers can go on fire. January 31, 2014 07:59AM |
umdpru
tjb1,
I'm not trying to make a one size fits all solution. The solution I proposed is for ABS printing with a J-Head. I never pretended that the thermal fuse was a solution to EVERY possible combination of printer design. That would be just silly.
Lastly, I'm not trying to prevent a fan from dying, nor am I trying to prevent damage to my printer. I'm trying to prevent my house from burning down. You can bet that a properly sized thermal fuse, if used within it's capabilities, will be better than not using one. In my situation, I have measured temperatures on my hotend that allow meto KNOW FOR CERTAIN that I can use a specific type of thermal fuse which will only allow the hotend to possibly melt down and then the fuse opens shutting down the printer entirely. I can't help you with your 500C E3D. You'll have to continue to poo-poo other's ideas on how to prevent their houses from burning down while the rest of us look for a solution.
Have a good one!
Have you ever seen a j-head fail at high temp? The heater assembly sometimes falls out of the top end so how will your fuse work then when its not near the heater and the heater is still running wild? Your idea is poo-poo
, difficult to implement at the correct location and gives false security. The only way I can see it being reliable is you take the 230 running/280 trip fuse and place it in another hole near the cartridge/resistor and keep your temps below 230 or try your luck and run it up to whatever below 280. You have too many variables placing the fuse away from the heater and if you want to then bet your house on that and sleep at night, more power to you.
Re: Yes, 3D printers can go on fire. January 31, 2014 11:59AM |
dave3d
Having the printer inside an enclosure fitted with a smoke alarm that triggers an automatic CO2 extinguisher system would be ideal.
However I cannot find an electrically operated CO2 system that doesn't cost an arm and a leg. Systems used for race cars and boats are also usually powder.
All it would take is a big nitrogen tank from the local welding supply...|
Re: Yes, 3D printers can go on fire. January 31, 2014 12:45PM |
Re: Yes, 3D printers can go on fire. January 31, 2014 01:02PM |
Re: Yes, 3D printers can go on fire. January 31, 2014 01:06PM |
dave3d
Yvan, my background is the chemical industry. I have never actually seen an automatic CO2 extinguisher system but I have seen dry powder systems. They are single use set off by a glass bulb that breaks at a preset temperature and releases the powder under pressure. The entire contents of the cylinder are discharged.
It would be possible I guess to design a system to use a nitrogen bottle particularly if the printer was sited in the garage. It would be cheap. Just a solenoid valve and maybe a timing circuit to shut it off after say a 30 second blast.
Re: Yes, 3D printers can go on fire. January 31, 2014 01:12PM |
Re: Yes, 3D printers can go on fire. January 31, 2014 06:03PM |
Re: Yes, 3D printers can go on fire. February 01, 2014 03:47AM |
Re: Yes, 3D printers can go on fire. February 01, 2014 05:40AM |
Re: Yes, 3D printers can go on fire. February 01, 2014 11:39AM |
A2
Yvan
Maybe a smoke detector in the fume hood could be hooked up to a relay controlling the exhaust fan.
If the fan was off, or marginally operational, the smoke detector wouldn't be effective located inside the ducting.
Re: Yes, 3D printers can go on fire. February 02, 2014 10:22AM |
Re: Yes, 3D printers can go on fire. October 18, 2014 05:26PM |
Re: Yes, 3D printers can go on fire. October 18, 2014 06:17PM |
CraigRK
Correct. Perhaps we should think about it like this:
- For each printer the hot end temp should increase in some ratio according to the amount of time max power is applied
- Could we track the power applied (time power was on) say over the last 5 minutes
- Track whether temp is decreasing significantly in the same time
- Correlate the 2. If we are applying power, then temp should be going up, not down
Sorry, not articulated very well. But rather than needing to set ranges or anything, the firmware should know if it is expecting the temp to rise, and if the temp actually drops, then warning bells should be ringing.
Then again, this is to cover the situation where the thermistor is pulled out of the hot end. I believe you can set Marlin to have 2 thermistors on the one hotend and stop based on a differential. This might be a quick win for people (although it presumes you have the hardware to make this a reality).
Re: Yes, 3D printers can go on fire. October 18, 2014 06:46PM |
Gregor R
What if you just wrap solder wire (without flux core) with the appropriate melting temperature with one or 2 turns around your extruder head. Insulating the wires from the extruder with Kapton before of course. Trough that solder wire you power your heating element. If now the extruder overheats the solder wire will melt and reliably cut the power to the heater.
Re: Yes, 3D printers can go on fire. October 19, 2014 06:46AM |
Re: Yes, 3D printers can go on fire. October 20, 2014 01:30AM |
Re: Yes, 3D printers can go on fire. October 20, 2014 04:53AM |
polyglot
I like the Pb-5Sn eutectic as thermal fuse idea
Until you get that tested, don't forget that there are bimetallic strips (with NC contacts rated for mains power, designed to be bang-bang thermostats) that can operate at higher temperatures than polymer thermal fuses. 250C seems readily available on eBay for <$5 and would work well to open a latched relay; I have a couple on the way and will test to see if one can hold reliably at 240C when bolted to a hotend.
A bimetallic strip shouldn't be damaged in the long term by operation just under the trip temperature, unlike a thermal fuse. And it's readily testable!
Re: Yes, 3D printers can go on fire. October 20, 2014 06:39AM |
UkIan
Could you link one please? I don't know what I'm looking for.
Re: Yes, 3D printers can go on fire. November 13, 2014 12:16PM |
Re: Yes, 3D printers can go on fire. February 20, 2015 11:44AM |
Re: Yes, 3D printers can go on fire. February 24, 2015 05:03PM |
