Check your hot end heater isn't lose! July 10, 2014 01:27AM |
Re: Check your hot end heater isn't lose! July 10, 2014 01:32AM |
Re: Check your hot end heater isn't lose! July 10, 2014 02:01AM |
Re: Check your hot end heater isn't lose! July 10, 2014 02:20AM |
Re: Check your hot end heater isn't lose! July 10, 2014 04:47AM |
Re: Check your hot end heater isn't lose! July 10, 2014 06:51AM |
Opus
The grub screw hadn't moved (i.e it took some torque to get it loosened) and the replacement heating element I'm just fitting didn't fit into the hole until I had loosened it. I guess the element deformed over time and changed shape enough to just slip loose.
Re: Check your hot end heater isn't lose! July 10, 2014 10:54AM |
Re: Check your hot end heater isn't lose! October 02, 2014 07:30PM |
Re: Check your hot end heater isn't lose! November 13, 2014 12:18PM |
Re: Check your hot end heater isn't lose! February 20, 2015 01:07PM |
