Cleaning the hot end on the fly
November 10, 2015 06:30AM
Guys hi again.
I was wondering if there are any ways to clean a hot end while it is attached to the printer ? I was wondering if some drops of acetone would do the job ? My printhead is not clogged but i need to clean it every now and then .
Thanks in advance,
Pavlos
Re: Cleaning the hot end on the fly
November 10, 2015 07:00AM
One way is to heat the nozzle to an appropriate temperature (about 100C for PLA), slowly retract the filament, cut off the end, and re-load the filament. The retracted filament brings with it any debris in the nozzle.
November 10, 2015 06:02PM
dc42
Is there a risk of pulling the lining out of the extruder or otherwise damaging it when doing this? For example, in a E3D lite6 where there is PTFE tubing all the way down.
See my blog at [moosteria.blogspot.com].
November 10, 2015 07:29PM
I've used this on an Ormerod nozzle with a PTFE liner - in fact this approach was recommended by RepRapPro who supplied the hot end kit.
December 12, 2015 10:58AM
That is the method that i am using . One day by mistake i retracted at high speed and i saw that this worked too. Some days ago i saw in a youtube a video saying that you have to retract at high speed and to tell you the truth i confused....!
Anyway for now i am retracting at low speeds and it seems to work pretty well.
December 12, 2015 01:47PM
The problem with retracting at high speed is that if the hot end doesn't have a PTFE liner (e.g. E3Dv6), then it brings molten filament into the cold part of the heat break and tends to jam. So the first 20mm of so of filament should be retracted slowly.
December 12, 2015 03:08PM
David do you know a good temp for retracting Abs ? I am now at 175c but i think i can go lower than this.
December 12, 2015 04:25PM
Gaou
No I don't, however the glass transition temperature is 105C so I think you may be able to go as low as 150C.
December 17, 2015 06:00AM
Don't know about retraction for cleaning purposes, but my only tip for filament removal with all metal hot ends is extrude an amount say 20mm then the moment it stops manually pull the filament briskly out so that it doesn't get chance to cool and 'bond' to the heatbreak throat on the way out.
Has anyone implemented a cleaning area for the nozzle to move to to effectively wipe itself before moving to the first coordinate and beginning to print. Slow continuous retraction taking place between the cleaning station and the first print coordinate should prevent ooze during travel without pulling hot filament back up and into the throat? 2D printers have nozzle wiping as part of their 'start gcode' which seems like a good idea.
December 20, 2015 02:13PM
I just pull out the filament. Sommetimes slowly. Other times fast. Sometimes at 100c ish (atomic cleaning) other times just at printning temp 210c ish.
Never had any issues with plastick Getting stuck in cold end/heatbreak of my E3Dv6 full (metal).
No need to overthink it.
My Instructables - both total newbie instructables and some for intermediate users.
My Designs on Thingiverse
YouTube channel containing a few 3D printing videos - they are videos for my Instructables, and mostly not standalone.
Ultius / Tantillus Thingiverse Group
