Wiring relay for Heatbed March 08, 2016 02:33PM |
Re: Wiring relay for Heatbed March 08, 2016 10:54PM |
Re: Wiring relay for Heatbed March 09, 2016 05:56AM |
Re: Wiring relay for Heatbed March 09, 2016 01:14PM |
amigob
this relay will work perfectly. Don't use a 5 volt one because you are going to connect the relay to the 12v heatbed output. of your ramps
using a fuse is a very good suggestion between the power supply and the relay, use high quality fuss box els it will also get very warm.
how many watts is your bed?
here is the datasheet
[www.mouser.com]
page 3 shows how to connect you have the '2 from A' version.
Re: Wiring relay for Heatbed March 09, 2016 03:59PM |
Re: Wiring relay for Heatbed March 10, 2016 09:45AM |
amigob
> The heat bed output pin from the ramps board will be 5v with a small current and the heated bed will be attached to the load side of the relay,
You do it again :-)
Where do you think that you will find the 5v on the ramps board ? It is 12V, how do you think that people attach the headbed directly to the ramps ?
0.25 A for the relay is peanuts for the heatbed connection also for the ramps , it was designed for the full current ( if you have a good ramps ) but even the very bad ones can easily handle 0.25A
If he has that relay use it. but don't expect that you can do PID with it.
Re: Wiring relay for Heatbed March 25, 2016 06:26AM |
