PEI VS PC sheet September 07, 2017 10:32AM |
Re: PEI VS PC sheet January 13, 2018 01:39PM |
Re: PEI VS PC sheet January 16, 2018 03:40PM |
Re: PEI VS PC sheet January 16, 2018 04:11PM |
Re: PEI VS PC sheet January 17, 2018 03:35AM |
Gaou
i have a piece of pei but i ve bought it without an adhesive by mistake so never use it. i wonder how much better it is than the printbite that i am using right now.
Re: PEI VS PC sheet January 17, 2018 02:25PM |
Srek
On my old machine i use a 0.8mm PEI coated fibersheet attached to the heatbed with clamps. On my new machine i put PEI foil on a magnetic sheet that already had a heat resistant adhesive. On the printbed i have the same magnetic sheet. This is an ideal combination for me since the magnetism prevents any buckling but allows for stretching. The magnetic sheets are acting as heat spreaders so i even get a very even heat distribution on the surface. Detaching a print couldn't be easier, i peel of the top sheet from the bottom sheet, then peel of the foil from the print.
[attachment 101588 DSCN2515a.JPG]
Re: PEI VS PC sheet January 17, 2018 03:20PM |
Re: PEI VS PC sheet January 17, 2018 06:45PM |
Re: PEI VS PC sheet January 18, 2018 03:24PM |
Re: PEI VS PC sheet January 20, 2018 12:37AM |
