Burned RAMPS power connector
Posted by tampe125
July 06, 2018 10:32AM
Hello,
today I was doing some maintenance on my 3D printer, while disconnecting the power supply to the RAMPS module I saw that a pin was completed burned (see attached picture).
Frankly, that's quite upsetting!
I built my 3D printer following Tom's guide on Dolly (Prusa MK2 clone) and I never had any issue with it. Sometimes I had some thermal runaway errors, but they were false positives (particle fan on bed temperature sensor).
Lately I had the board shutdown when it's too hot: I got no errors, simply it stopped moving and heating, then the thermal protection kicks in. I added a PC fan next to electronics and it solved the issue.
I know RAMPS aren't the best available board, but I just wanted to know if that's something that happens from time to time or I did something wrong.
Any ideas?
open | download - IMG_20180706_161613490.jpg (766.2 KB)
VDX
Re: Burned RAMPS power connector
July 06, 2018 11:01AM
... this is common for drawing more current, than the connectors are designd for -- or bad coating/oxidizing eye rolling smiley
Viktor
Aufruf zum Projekt "Müll-freie Meere" - [reprap.org]
July 07, 2018 11:51AM
Could it be an undersized wire?
I was thinking on switching on bigger ones
VDX
July 07, 2018 03:40PM
... this was not the wire but the connector pins! - you'll need a connector, designed for more current ... or reduce the drawn current to a "safe" level ...
Viktor
November 23, 2018 03:04PM
This is a common reason why people use add-on MOSFET boards to redirect current away from the controller board. The controller board only performs the switching of the MOSFET through control wires while the power for the heated bed passes through the MOSFET module. The connectors on such modules are usually better too--gold plated or copper broad terminals, in which you may insert crimped wires. BIQU style MOSFET modules can be bought for around $3.50, which is good insurance against damaging the RAMPS or starting a fire.
If you don't wish to purchase such a module, a best practice is to crimp your wire ends with ferrules before securing them in the screw terminals of the "Phoenix" quick release connector. Also, make sure you add a heat sink to the first (D8) MOSFET--as large as you can find/install.
