Add custom reset button
Posted by tampe125
August 26, 2018 11:11AM
Hello everyone,
I'm currently using a Prusa i3 clone that I built on my own, using the RAMPS 1.4 shield.
The reset button is quite handy when something goes wrong, but at the moment is not very easy to reach (I built an enclosure and all the electronics are screwed on the bottom of the table).
Is there a way to add a custom reset button without de-soldering the current mini-button on the RAMPS?
Re: Add custom reset button
August 26, 2018 11:18AM
just wire another button to the legs of the current button, no need to desolder it
August 26, 2018 12:16PM
When I used a ramps, I just soldered a two pin header on the bottom, sticking out the side of the reset button connections underneath to connect another one else where.
August 29, 2018 09:34AM
Thank you everyone!
I simply soldered the wires from the bottom of the existing button and everything's working smooth.
Thanks again!
