Re: Grounding June 29, 2024 03:28AM |
PCLoadPLA
Should a 3D printer have the ground lug of the AC power cord connected to the printer frame i.e. have the printer frame tied to building / earth ground?
PCLoadPLA
Should the "negative" wire coming from the 24V power supply, also be tied to the same "frame ground / earth", or left separate?
PCLoadPLA
What other points of the printer should be "grounded", for example should an aluminum moving heatbed that rolls on POM wheels, which is otherwise isolated from the printer frame, also be grounded? Doing so will require a dedicated grounding wire, and I don't see such a wire on most printers....
Re: Grounding July 10, 2024 06:59PM |
Re: Grounding July 11, 2024 08:33AM |
