Opinions on this printer? November 18, 2015 12:45PM |
Re: Opinions on this printer? November 18, 2015 01:31PM |
Re: Opinions on this printer? November 18, 2015 02:07PM |
Re: Opinions on this printer? November 18, 2015 03:08PM |
But do you have access to a workshop that can fabricate the metal parts? Otherwise you will probably be better off with Filipe's design. As he says, his is much like it, just with much more printed parts. He has a very long thread here in the forum.
If you are comfortable working with wood then you may also consider the smartcore printer.
It would be easier to provide inputs if you compose a list like:
* What kind of equipment do you have access to (3d printer?, CNC?, laser cutter?, wood workshop?, metal workshop?, awesome makerspace?)
* What kind of money are you willing to spend
* Do you plan to continue expanding on your printer - Like, would you like to add two colour option later, or will you make your printer according to the drawing and be happy?
Taking my last bullet as an example - The Eclipse3D would be awesome as a platform for future own-development because it is so "Lego' ish" (modular) in its construction - The Smartcore less so.
Re: Opinions on this printer? November 18, 2015 03:52PM |
Re: Opinions on this printer? November 18, 2015 04:37PM |
filipeCampos
The eclips3d is a better printer in relation of the g&c printer but is cost is far superior. The total cost of the eclips3d is arround 800 euro and the g&c is 500 euro.
I give you an simple exemple, the bed struture of the eclips3d will be something like 180 euro.
You will spend a lot more of 200 euro if you go with an all aluminium printer like the eclips3d.
With this money an good option is the smartcore.
Re: Opinions on this printer? November 18, 2015 05:12PM |
Re: Opinions on this printer? November 19, 2015 04:56AM |
Re: Opinions on this printer? November 20, 2015 09:18AM |
250-300 euros sounds about the same as what I calculated. But building and eventually selling the prusa sounds like a good option.Quote
filipeCampos
Funny, because this is something i have already done before. My first printer was an prusa i3 steel printer.
Initially i have the same idea, use the material of the prusa to build the new one (g&c printer).
After some thinking i have decided not to reuse the material of the prusa i3 and to buy all new material.
I think at the end i have done the correct decision, i have done this wasy because of two reasons:
1) I need to have an second functional printer to build the new one. Is difficult to print all the pieces of the new printer at the first try.
2) after the new printer is build you can sell the prusa, at the end is an cheaper solution. If you reuse the pruse material you will have a lot of material (prusa structure, rodds, bed structure, etc..) that is not easy to sell and do not have utility to you. I have sell my prusa at 80% of is original cost, only lost 20% of my initial money.
if i remember correctly the total cost of building the g&c reusing the prusa material was between 250 to 300€.
Re: Opinions on this printer? November 20, 2015 10:02AM |
Re: Opinions on this printer? December 02, 2015 06:44AM |
Re: Opinions on this printer? December 02, 2015 09:11AM |
Re: Opinions on this printer? December 02, 2015 09:37AM |
Re: Opinions on this printer? December 02, 2015 10:16AM |
