I'm well on my way to building a D-bot and have got to the stage of fitting a 200 x 300 mm heated bed.
It looks as if the design has it sitting on 4 springs with level adjustment bolts to attach to the bed supports.
The heater is very flimsy and is sagging in the middle of the long sides and with a glass plate on top I would have lost contact with the heat bed at the centres.
I am wondering if another support should be fitted along the centre, or is there another better way of doing things
I was going to use cork as an insulator but that is also flimsy, should I use a piece of plywood?
Thanks for any help
appjaws - Core XYUV Duet Ethernet Duex5
firmware 3.1.1 Web Interface 3.1.1
Ormerod 1-converted to laser engraver, Duet wifi
OpenSCAD version 2020.07
slic3r-1.3.0, Simplify3D 4.1.2, Cura-4.4.1
