Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? December 07, 2016 03:12AM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? December 07, 2016 11:48AM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? December 07, 2016 12:27PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? December 07, 2016 04:14PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? December 07, 2016 08:58PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? December 08, 2016 08:27AM |
the_digital_dentist
Worst case is when you're making 45/135 degree lines - only one motor is turning and must move both X and Y axes. As long as each motor has adequate torque to move both masses with the speed, acceleration, jerk, and precision you want, it will work fine. The X and Y axis performance will necessarily be different because you're using one set of motors to move the axes. The Y axis is higher mass than the X axis, so the Y axis performance will always be worse than the X axis performance. The 45/135 degree performance will define the limits of the machine- moving mass is highest and torque to move it (supplied entirely by one motor) is lowest.
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 04, 2017 09:01AM |
realthor
One thought, with corexy would it be possible somehow to balance the two axes by assigning different accellerations, etc so that the performance of the Y gets closer to the one of X? Just a thought...
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 06, 2017 03:42PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 07, 2017 06:33AM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 07, 2017 12:29PM |
DjDemonD
... but no firmware allows for corexy operation with different movement settings for A and B motors.
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 14, 2017 07:52PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 14, 2017 08:16PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 14, 2017 11:10PM |
the_digital_dentist
When I manually move one motor in my coreXY mechanism, the detent torque of the other motor (and friction) is sufficient to prevent it from turning. The second motor is not contributing to the motion whether it is powered or not.
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 15, 2017 04:49AM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 15, 2017 07:15AM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 15, 2017 02:19PM |
the_digital_dentist
"negative energy", "fluctuating equilibrium"? Gimme a break... I think you've been studying too many youtube videos of perpetual motion/free energy scams.
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 15, 2017 06:39PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 17, 2017 02:22AM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 17, 2017 03:54AM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 17, 2017 12:34PM |
DjDemonD
So which unbalanced loads in a standard corexy does the design above compensate for then?
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 17, 2017 01:01PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 17, 2017 03:25PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 17, 2017 04:17PM |
Re: Are the two different masses of the XCarriage and whole Y+X gantries for the other mass a real issue? January 17, 2017 04:36PM |
