My Core XY Build February 14, 2017 02:12PM |
Re: My Core XY Build February 14, 2017 04:07PM |
Re: My Core XY Build February 14, 2017 04:13PM |
Re: My Core XY Build February 14, 2017 05:36PM |
Re: My Core XY Build February 14, 2017 06:56PM |
Re: My Core XY Build February 14, 2017 07:59PM |
Re: My Core XY Build February 14, 2017 08:00PM |
the_digital_dentist
The belt connection to the extruder carriage will have to be redone. Those belt segments must be made parallel to the X axis, otherwise prints will be distorted and you'll probably have trouble keeping the belts on the pulleys because the tension will change depending on where the extruder is in XY space. I can't tell from the picture, but the variable length belt segments along the Y axis rails have to be parallel to those rails for the same reason.
Re: My Core XY Build February 15, 2017 12:30AM |
Re: My Core XY Build February 15, 2017 04:33AM |
theory
So essentially all belt paths need to be as straight and parallel to the x and y axis as possible?
Re: My Core XY Build February 15, 2017 07:59AM |
Re: My Core XY Build February 15, 2017 08:15AM |
o_lampe
Would it help to use bigger OD idlers on the H-beam? That way you only have to print a sleeve that fits over the actual bearings.
Re: My Core XY Build February 15, 2017 10:06AM |
Re: My Core XY Build February 15, 2017 03:05PM |
the_digital_dentist
The variable length segments have to be parallel to their respective guide rails. The segments that are fixed length (the ones that run between fixed pulleys or between the motor and a fixed pulley) don't matter.
This is what it should look like:
Re: My Core XY Build March 07, 2017 08:30AM |
Re: My Core XY Build March 07, 2017 09:42AM |
Re: My Core XY Build March 07, 2017 10:51AM |
Re: My Core XY Build March 07, 2017 02:30PM |
Re: My Core XY Build April 05, 2017 01:14PM |
Re: My Core XY Build April 05, 2017 02:24PM |
Re: My Core XY Build April 05, 2017 02:55PM |
Re: My Core XY Build April 05, 2017 03:32PM |
Re: My Core XY Build April 05, 2017 07:45PM |
Re: My Core XY Build April 05, 2017 11:53PM |
Re: My Core XY Build April 06, 2017 12:14AM |
the_digital_dentist
I really don't understand the 3D printing community's love of glass and all the silly stuff that has to be done to make it work. Just get a piece of cast tooling plate, put a thin layer of PEI on it and you're done -no problems with parts letting go before the print finishes, and no need to put gooey stuff on the bed. Yeah, it costs a few $ more up front, but in the long run it's probably cheaper than any other option, because you won't waste so much time and material on failed prints, and you won't have to keep "feeding it" with glue and other crap, and replace broken glass plates.
Re: My Core XY Build April 06, 2017 12:42AM |
the_digital_dentist
Do the X axis guide rails have solid endstops inside the bearing blocks at their ends? If not, the belt tension is probably pulling those blocks inward which will flex the Y axis guide rails. That will lead to problems moving the X axis assembly along the Y axis rails. Another possibility is that the X axis rails are flexing due to the belt tension, which allows the Y axis rails to flex inward, causing the same problem. If the belt tension isn't pretty close to matched, the X axis may tilt relative to the Y axis and put a lot of pressure on the Y axis bearings. End supported rails can be a b**ch...
Re: My Core XY Build April 06, 2017 08:18AM |
Re: My Core XY Build April 06, 2017 01:40PM |
Re: My Core XY Build April 09, 2017 10:10AM |
Re: My Core XY Build April 09, 2017 10:20AM |
