New Printer Design February 28, 2018 12:16PM |
Re: New Printer Design February 28, 2018 12:43PM |
Re: New Printer Design February 28, 2018 01:37PM |
Re: New Printer Design February 28, 2018 04:33PM |
Re: New Printer Design February 28, 2018 11:45PM |
Re: New Printer Design March 01, 2018 03:18AM |
Re: New Printer Design March 01, 2018 06:30AM |
Re: New Printer Design March 01, 2018 08:14AM |
Re: New Printer Design March 01, 2018 10:10AM |
Re: New Printer Design March 01, 2018 10:57AM |
Re: New Printer Design March 01, 2018 11:06AM |
deckingman
The other big factor is that there is no way on God's earth that you could accelerate the melt rate and extrusion of the filament at anything like those speeds. If you try, all you'll get is a pressure pulse but the molten filament won't accelerate out of the nozzle as fast as the print head, so you'll get under extrusion at the start of every move.
Re: New Printer Design March 01, 2018 02:43PM |
......... it doesn't take much force to deflect the end-effector by ~0.1mm relative to the bed, and that kind of error will be visible in the final print.
A kilogram of force might not sound like much on paper, but as a fast impulse it has punch. Even worse, infill patterns have a way of hitting reasonant frequencies which can be very unpleasant. I have a printer that can reach 10m/s2 of acceleration and it feels like the printer and desk are being hit with a mallet.
At high accelerations pretty much everything becomes suspect, for example an E3D v6 heatsink hanging out of a plastic groovemount will swing around like a wet noodle. You also need to worry about the machine walking away.
At infinite acceleration the print head can instantaneously change direction and therefore its speed never changes. Low accelerations force you to constantly vary print speed (depending on how long your line segments are) which creates blobbing and related artifacts.
At high accelerations you only run into problems at the start and end of a complete segment or layer, and if you can rapid to the new print location fast enough even that becomes irrelevant. The extruder can spend the entire print pushing filament at a single constant speed.
Re: New Printer Design March 01, 2018 02:47PM |
Speaker-2-Animals
@prot0typ1cal
When googling around for ideas for printers I came across pictures of your Hlidskjalf and it inspired this one even though mine won't be nearly as impressive. Yes those are 9mm belts on the gearing but it's 3:1 ratio 60 and 20 tooth pulleys. Based on your experience do you think 3:1 is too much? I know it's going to limit travel speed but I think print speeds will benefit from better resolution and torque.
Re: New Printer Design March 01, 2018 02:57PM |
Re: New Printer Design March 01, 2018 03:48PM |
Re: New Printer Design March 01, 2018 04:44PM |
deckingman
So on the one hand you say this..............
Re: New Printer Design March 01, 2018 05:03PM |
Re: New Printer Design March 01, 2018 06:57PM |
Re: New Printer Design March 02, 2018 04:36AM |
Re: New Printer Design March 08, 2018 11:40AM |
