new build (needs a name ) May 28, 2018 07:42AM |
Re: new build (needs a name ) June 06, 2018 03:18PM |
Re: new build (needs a name ) now called THOR ! June 15, 2018 02:33PM |
Re: new build (needs a name ) now called THOR ! June 15, 2018 06:50PM |
Re: new build (needs a name ) now called THOR ! June 15, 2018 08:36PM |
Re: new build (needs a name ) now called THOR ! June 16, 2018 06:43AM |
Re: new build (needs a name ) June 16, 2018 11:49PM |
Re: new build (needs a name ) June 17, 2018 03:46AM |
Re: new build (needs a name ) June 17, 2018 08:20AM |
Re: new build (needs a name ) June 17, 2018 12:37PM |
Re: new build (needs a name ) June 18, 2018 11:30AM |
Re: new build (needs a name ) June 18, 2018 12:19PM |
adambrum
If i have a steel rail on aluminium then the aluminium expands approx 0.2mm more than the rail,
If i have a steel rail on carbon fibre then the steel expands more than the carbon fibre, cant find any actual data
So the solution must be steel rail on a steel tube or angle with an extra bearing on y-axis but that increases the weight which im trying to reduce or i could machine a groove in aluminium bolt the rail tightly in the middle and nip up the rest allowing it to expand less that the aluminium.
Re: new build (needs a name ) June 18, 2018 01:46PM |
