Print not centering on build plate May 26, 2018 04:39PM |
Re: Print not centering on build plate May 27, 2018 03:05AM |
Re: Print not centering on build plate May 27, 2018 10:15AM |
o_lampe
You have to set the origin in Marlin and slic3r the same way. ( eg. bed center at 0,0 )
IMHO you have to set slic3r offset to +105,+105 and leave Marlin as_is.
BTW: You can disable autocenter parts in slic3rs preferences, just to get you printing. Just move the part to a position, your printer can actually print it.
Re: Print not centering on build plate May 28, 2018 12:59PM |
Re: Print not centering on build plate May 30, 2018 06:08PM |
the_digital_dentist
Where is the bed located within that 230x250 mm space? The printer thinks of motion in its coordinate space, and the slicer has its own coordinate space shifted (usually) relative to the printer's coordinate space. The slicer's origin is always on the corner of the bed. The printer's origin may or may not be on the bed.
Take a look at this: [drmrehorst.blogspot.com] and this: [drmrehorst.blogspot.com]
Slic3r is usually pretty easy to set up, Cura a little harder because you have to use some custom gcode to tell it where the origin of the bed is located.
Re: Print not centering on build plate May 30, 2018 09:23PM |
Re: Print not centering on build plate May 31, 2018 03:05AM |
Re: Print not centering on build plate September 20, 2018 01:03AM |
Re: Print not centering on build plate September 20, 2018 06:30AM |
Re: Print not centering on build plate September 20, 2018 07:12AM |
Re: Print not centering on build plate September 20, 2018 09:41AM |
Re: Print not centering on build plate September 20, 2018 10:20AM |
Yes the problem is i don't think so, because when printing in the corner and hitting one of the endstops it tells position on pronterface and this differs slightly sometimes for ex. y coordinate is shown triggered endstop at 97.5 or on another try at 96.7. so the mechanismn isn't working probably.Quote
the_digital_dentist
Of course, it assumes that the printer's mechanism is working properly...
Re: Print not centering on build plate September 20, 2018 12:07PM |
