Z axis
Posted by nebula39
Z axis
January 28, 2019 09:31PM
Hello everyone,
I have an Flsun Cube which I have been happily using for more then a year now. I decided to convert it to a core xy/ hypercube mod from thingiverse. I thought I had all the marlin setting correct but when I go to print it will mess up.
The bed will heat up fine then it will home all three axis but when it start to heat the head the z axis starts moving down, away from the head. I have to use the emergency stop to shut it down.
Any thought would be greatly appreciated.
Re: Z axis
January 29, 2019 11:57AM
sounds like a wiring or pin definiton problem...
verify both.
What control board...
did you change the controller?
is this different firmware than before?
Re: Z axis
January 30, 2019 06:36PM
I have a ramps clone. I did change boards from my original when I was first having problems with the core xy program. Although I have always been running marlin for my firmware. I will switch back to my old board and see how it runs after loading the firmware settings I have now.
