5mm idler spacers? January 14, 2020 09:16PM |
Re: 5mm idler spacers? January 14, 2020 11:17PM |
Re: 5mm idler spacers? January 15, 2020 01:39AM |
Re: 5mm idler spacers? February 02, 2020 08:41PM |
Re: 5mm idler spacers? February 04, 2020 06:07PM |
the_digital_dentist
Cut a piece of plastic tubing...?
Print washers...?
Punch holes in thin plastic and trim with scissors...?
The bearings in those little pulleys are so tiny that they won't last very long under belt tension. It's better to stack flanged bearings to make pulleys. F625zz bearings can be used to make good, long life pulleys for 6 mm belt. F608zz bearings can be stacked to make pulleys for 9 or 10mm wide belt.
