echo: too long extrusion prevented
Posted by Jagtech
April 23, 2017 12:12PM
I built a hypercube printer and everything is working but my extruder motor. I can swap the motor connector to the x or y axis and motor works verifing the motor curcuit is ok swaped drivers and driver ok. When I try to extrude in prompterface I get (echo: too long extrusion prevented) Help please
Re: echo: too long extrusion prevented
April 23, 2017 03:46PM
This is not a CoreXY thing, but Marlin (which you didn't specify). Disable PREVENT_LENGTHY_EXTRUDE in configuration.
November 22, 2021 09:30PM
I guess you found out by now, but
M302 S0 ; disable all extrusion checking
Just borrowing this thread, is there a way to re-enable PREVENT_LENGTHY_EXTRUDE after the above command? I tried M302 S170 and re-enabled PREVENT_COLD_EXTRUSION, but not PREVENT_LENGTHY_EXTRUDE
