Re: Atfer Hbot, go to CoreXY. March 28, 2014 07:24PM |
Re: Atfer Hbot, go to CoreXY. March 28, 2014 07:43PM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 04:07AM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 11:02AM |
Mogal
When it come to the extruded parts, its $16 a meter here. That's for 1"x1" (25mm profiles)
It's mostly awesome living on an island, but sometimes it really sucks.
Re: Atfer Hbot, go to CoreXY. March 29, 2014 02:09PM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 04:04PM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 04:43PM |
! please don't complain with TAX mogal
, here in Europe Tax is very expensive and always more or less 20%, and I don't think Europe is a small island...
Re: Atfer Hbot, go to CoreXY. March 29, 2014 05:05PM |
zelogik
@mogol: Jand have all right and same question as jand, what's your plan for the belt path with motor outside...? MDF can't be bad, but on island I think you have some humidity, so dimensions change, so don't hesitate to paint or put some resin on it, or it's will be painful for Z calibration.(like first makerbot or first ultimaker on humide "ground/land")
The link with video you have posted for the protoforge 3d printer is an HBot, there my plan and Jand's fork is a CoreXY system, not exactly the same things. Hbot is more simple to design but you need really tight tolerance free linear mouvement (really expensive) or you will have many cantilever/backlash problem. And with CoreXY, design is more difficult to be done( but there it's not a problem, I have already "brainded", engineered that for the community ;-)), but you can use really cheap linear bearing (lm8uu or igus), but need more pulley and two belts instead of one longer belt.
So you just need to modify a little bit each corner (only for the beauty of the thing not for the functionnality) for filling the part missing where the extrusion profile goes.
Yes reinhald! please don't complain with TAX mogal
Finally yes your design is really nice for mdf, maybe you don't need to make a big windows for each plate, close wall is better for keep heat inside for ABS printing.
@Jand: Be careful with nickname, for me it's zelogiK and it's not mogol but mogAl :-D, and sorry to don't have respond to you, don't have time for see your plans.
Have you enought info/photos for limit switch?
@Reinhald, Chain cable wasn't so cheap finally ... 12€ for 1meter on ebay, the next time I will print it, I have seen many on thingiverse yesterday...
Re: Atfer Hbot, go to CoreXY. March 29, 2014 05:28PM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 05:30PM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 05:46PM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 06:22PM |
Re: Atfer Hbot, go to CoreXY. March 29, 2014 07:32PM |
Re: Atfer Hbot, go to CoreXY. March 30, 2014 05:24AM |
Re: Atfer Hbot, go to CoreXY. March 30, 2014 05:28AM |
). You have a big moment between X carriage rod, and X carriage belt fixation (the distance is really important). I don't know if somebody can understand me.
) but you can see that there is no moment at all between belt and rod, each time you pull/tight the belt, the rod is on the same axis than the belt.|
Re: Atfer Hbot, go to CoreXY. March 30, 2014 06:40AM |
Re: Atfer Hbot, go to CoreXY. March 30, 2014 07:22AM |
Re: Atfer Hbot, go to CoreXY. March 30, 2014 07:40AM |
Re: Atfer Hbot, go to CoreXY. March 30, 2014 11:26AM |
Re: Atfer Hbot, go to CoreXY. April 03, 2014 04:56AM |
Re: Atfer Hbot, go to CoreXY. April 03, 2014 08:30AM |
leadinglights
... not totally convinced that I inderstand what is meant by "racking" I thought that this thread was the best place ..
Mike
Re: Atfer Hbot, go to CoreXY. April 03, 2014 09:01AM |
Re: Atfer Hbot, go to CoreXY. April 08, 2014 12:21AM |
Re: Atfer Hbot, go to CoreXY. April 08, 2014 02:03AM |
Re: Atfer Hbot, go to CoreXY. April 08, 2014 03:41AM |
Re: Atfer Hbot, go to CoreXY. April 08, 2014 04:26PM |
zelogik
... So I need to thinking a way for put extruder motor on the moving carriage for the first extruder,
Re: Atfer Hbot, go to CoreXY. April 14, 2014 06:05PM |
Re: Atfer Hbot, go to CoreXY. April 17, 2014 02:27PM |
Re: Atfer Hbot, go to CoreXY. April 17, 2014 04:41PM |
Re: Atfer Hbot, go to CoreXY. April 17, 2014 07:06PM |
