Re: Atfer Hbot, go to CoreXY. May 11, 2014 10:38AM |
jand
"foudroyante", Google translate was not very helpfull.
Too bad now that I'll have to buy the parts in your BOM
Re: Atfer Hbot, go to CoreXY. May 11, 2014 02:35PM |
Re: Atfer Hbot, go to CoreXY. May 13, 2014 07:20AM |
Re: Atfer Hbot, go to CoreXY. May 13, 2014 07:47AM |
Re: Atfer Hbot, go to CoreXY. May 22, 2014 03:55PM |
Re: Atfer Hbot, go to CoreXY. May 22, 2014 05:41PM |
Re: Atfer Hbot, go to CoreXY. June 01, 2014 12:32PM |
Re: Atfer Hbot, go to CoreXY. June 01, 2014 01:53PM |
zelogik
That describe not round circle with Corexy system.
I have uploaded EXACTLY my same firmware (repetier), just change that line: #define DRIVE_SYSTEM 0 (from 1 before)
and M206 T3 P3/P7 X458 to divide by square(2). And now circle are round, space between infill line have all equal distance. The only downside for the moment, the build area is smaller and the printer is 45° rotated.
Re: Atfer Hbot, go to CoreXY. June 01, 2014 02:03PM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:00AM |
zelogik
I have made many discovery... The first one, 0.9° stepper motor make really less noise than 1.8° (maybe because their are more powerfull too) . :-D
... actually they are only "more powerful" because (I bet) they are 48mm long vs. 40mm or less in
The second one, and not only for that printer but for ALL hbot and CoreXY gantry. With Marlin & Repetier firmware.
... not round circle with Corexy system.
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:40AM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:51AM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 06:02AM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 06:18AM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 08:54AM |
genelmx
I am going to print and test it out anyway...
Re: Atfer Hbot, go to CoreXY. June 02, 2014 11:14AM |
, But I have choose 2.4A. So they don't run at 100% efficiency but make less noise
(now i have the problem of the fan noise to have a correct WAF
(12teeth to 30teeth without problems normally).
Re: Atfer Hbot, go to CoreXY. June 02, 2014 12:31PM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 02:02PM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 02:11PM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:29PM |
Sry ... usually I make a point to read all, especially the end ... just missed you!Quote
zelogik
..checked Github (you even can seen my nickname around)
Please use Sidelights (éclairage oblique) to accentuate the emerging texture and material and switch your camera to "aperture mode" with the smallest aperture you can hold steady. There will be much more to see than just infill-infill-empty-infill-infillQuote
zelogik
I need to take photo on two print,..
WHERE do I get 12teeth, 5mm bore GT2 pulley ??? PLEASE!Quote
zelogik
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:39PM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:40PM |
zelogik
@jand, dont need to print exactly the same object. Can you take a picture of a top of print or/and a rectilinear filling during printing :-)
Repetier bug... Maybe tomorrow i will give a try with marlin.
...I believe jand is using A4988 (and Marlin) - correct?Quote
Repetier (Marcus Littwin)
The DRV8825 often used for 32 microstepping needs longer step high signals.
So firmware is too fast. Solution is to set stepper high delay to 1 or 2us (RADDS).
In online config tool you need to enable expert settings to see that option.
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:49PM |
Re: Atfer Hbot, go to CoreXY. June 02, 2014 05:51PM |
Re: Atfer Hbot, go to CoreXY. June 03, 2014 02:12PM |
Re: Atfer Hbot, go to CoreXY. June 03, 2014 05:16PM |
zelogik
Edit: Or it's perpendicular axis problem between X and Y !!! Somebody have an easy way for controlling that ?
I am (really) not sure what you are telling (me) but does:
Re: Atfer Hbot, go to CoreXY. June 04, 2014 04:26PM |
Re: Atfer Hbot, go to CoreXY. June 04, 2014 04:45PM |
Re: Atfer Hbot, go to CoreXY. June 04, 2014 05:04PM |
, you don't have the same problems as me.|
Re: Atfer Hbot, go to CoreXY. June 04, 2014 05:56PM |
