Re: Atfer Hbot, go to CoreXY. June 09, 2014 09:39PM |
Re: Atfer Hbot, go to CoreXY. June 10, 2014 03:05PM |
Re: Atfer Hbot, go to CoreXY. June 10, 2014 03:36PM |
Re: Atfer Hbot, go to CoreXY. June 10, 2014 05:08PM |
zelogik
I have put a droplet of oil on the rod and MAGIC !!! no more backlash
_ _ _ _ __ ___ _ _ __ _ _ _ __ _| |_ _ _| |__ _| |_(_)___ _ _ ___ / _/ _ \ ' \/ _` | '_/ _` | _| || | / _` | _| / _ \ ' \(_-< \__\___/_||_\__, |_| \__,_|\__|\_,_|_\__,_|\__|_\___/_||_/__/ |___/Fairy-oil-recipes
Re: Atfer Hbot, go to CoreXY. June 10, 2014 06:30PM |
zelogik
I have put a droplet of oil on the rod and MAGIC !!! no more backlash It's was a stick-slip problem.
Re: Atfer Hbot, go to CoreXY. June 11, 2014 06:55AM |
Re: Atfer Hbot, go to CoreXY. June 11, 2014 03:35PM |
marcossf
(corexy) I will upload some photos when it be done..
Don't worry! - We are here to reprap, not to give "grades for english (american)?"Quote
(I know, my english suck... Sorry).
Re: Atfer Hbot, go to CoreXY. June 11, 2014 04:11PM |
Re: Atfer Hbot, go to CoreXY. June 11, 2014 04:52PM |
Re: Atfer Hbot, go to CoreXY. June 11, 2014 06:47PM |
Re: Atfer Hbot, go to CoreXY. June 13, 2014 02:20PM |
Reinhold
YES Marcos please do ...if you have enough material open a new thread ... and let us know where we find it.
Re: Atfer Hbot, go to CoreXY. June 20, 2014 11:15AM |
Re: Atfer Hbot, go to CoreXY. June 20, 2014 11:59AM |
Re: Atfer Hbot, go to CoreXY. June 20, 2014 01:34PM |
Dejay
Hey Marcossf, that frame looks pretty cool. How is that drylin Q carriage working out? It's pretty expensive on motedis.com, is there cheaper sources for something like that?
I'm been thinking about making a modified version of Johann's linear motion carriage with recirculating delrin / acetal spheres, so that it encapsulates a standard extrusion. The spheres would cost about 3$ for 100 and you would need 80 for four recirculating paths. That would even be cheaper than 4 or 6 wheels per extrusion. It should be reasonably precise as long as the main path where the spheres roll along is precise.
Re: Atfer Hbot, go to CoreXY. June 20, 2014 04:28PM |
Why would you want to use an M10 threaded rod ? (instead of M8)Quote
pando855
M8 to M10
Re: Atfer Hbot, go to CoreXY. June 20, 2014 05:54PM |
Re: Atfer Hbot, go to CoreXY. June 20, 2014 07:20PM |
Re: Atfer Hbot, go to CoreXY. June 21, 2014 04:37AM |
Re: Atfer Hbot, go to CoreXY. June 28, 2014 09:28PM |
Reinhold
- tap a M8 thread into the "extrusion center hole" (of one of the 2 short extrusion pieces)
Re: Atfer Hbot, go to CoreXY. June 30, 2014 07:28AM |
nhathaitrieu6
Hi zelogik and jand, is there any reason why the motor mount cannot be direct? What I mean is, remove the 2 idler pulleys in the motor block, and the 90degree bend from motor block to XY block. I have attached a picture to make it clearer.
Re: Atfer Hbot, go to CoreXY. July 02, 2014 04:38PM |
Re: Atfer Hbot, go to CoreXY. July 05, 2014 04:41AM |
Re: Atfer Hbot, go to CoreXY. July 11, 2014 01:16PM |
Re: Atfer Hbot, go to CoreXY. July 12, 2014 05:54PM |
marcossf
One question to all of you
Where to buy shoulder screws (4mm and 5mm shoulder diameter and 25 mm shoulder long)?? I was unable to find everywhere and also its hard to find on internet.
Re: Atfer Hbot, go to CoreXY. July 14, 2014 11:32AM |
Re: Atfer Hbot, go to CoreXY. July 17, 2014 08:03AM |
Re: Atfer Hbot, go to CoreXY. July 22, 2014 06:08PM |
Re: Atfer Hbot, go to CoreXY. July 23, 2014 07:15AM |
Re: Atfer Hbot, go to CoreXY. July 23, 2014 09:10AM |
Re: Atfer Hbot, go to CoreXY. July 23, 2014 05:12PM |
