Re: Atfer Hbot, go to CoreXY. October 09, 2014 02:02PM |
Re: Atfer Hbot, go to CoreXY. October 09, 2014 03:49PM |
Re: Atfer Hbot, go to CoreXY. October 09, 2014 04:45PM |
Re: Atfer Hbot, go to CoreXY. October 10, 2014 06:41AM |
Re: Atfer Hbot, go to CoreXY. October 10, 2014 08:08AM |
Re: Atfer Hbot, go to CoreXY. October 10, 2014 10:57AM |
misan
@marcossf your z-axis rods should be aligned with bearing axis for best performance.
Re: Atfer Hbot, go to CoreXY. October 10, 2014 01:57PM |
Re: Atfer Hbot, go to CoreXY. October 10, 2014 03:19PM |
brucehvn
cfeniak
Well, after H-bot.... I went core XY! Should of heeded the warnings
Here is my build:
Core XY on Open Builds
You can see a picture of my original H-Bot in the discussion forum.
Hard to tell from the photos, but could you elaborate on how the z-axis is constructed? I see the two motors with the 8mm threaded rod (are these OpenBuilds leadscrews?) on one side. Is the other side of the platform supported at all or is it only supported on the one side. I'm designing my own core x/y right now which will also use v-slot exclusively for the linear motion. I'm kicking around various ideas on how to handle the z-axis and whether one supported on just one side with the v-wheels will work effectively.
Re: Atfer Hbot, go to CoreXY. October 13, 2014 05:54AM |
Re: Atfer Hbot, go to CoreXY. October 13, 2014 05:57AM |
Re: Atfer Hbot, go to CoreXY. October 14, 2014 06:54AM |
misan
@marcossf: then I guess it is 200x32=6400 steps/rev
Re: Atfer Hbot, go to CoreXY. October 14, 2014 07:17AM |
marcossf
misan
Nope, you're wrong.
Steps_per_mm = (motor steps * motor microsteps) / lead screw pitch
3200 = (200*32)/2 With 1/32 microsteping
1600 = (200*16)/2 With 1/16 microsteping
1.8º motor steps/rev = 360º/1.8º = 200 steps/rev.
Trapezoidal lead screw 10mm diameter, 2 mm pitch/rev.
Re: Atfer Hbot, go to CoreXY. October 14, 2014 07:32AM |
Re: Atfer Hbot, go to CoreXY. October 14, 2014 08:10AM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 09:29AM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 09:44AM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 09:51AM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 11:11AM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 11:14AM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 11:33AM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 12:32PM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 02:19PM |
Re: Atfer Hbot, go to CoreXY. October 16, 2014 05:10PM |
Admin Registered: 11 years ago Posts: 3,096 |
pelo13
another problem occurred .. after i homing the printer i didn't get any further moves from my printer ... any ideas?
Re: Atfer Hbot, go to CoreXY. October 17, 2014 05:15AM |
Re: Atfer Hbot, go to CoreXY. November 09, 2014 06:54AM |
Re: Atfer Hbot, go to CoreXY. November 09, 2014 11:48AM |
peterv3210
I modified the belt-clamp because I was struggling to get the belt tensioned without slipping out of the belt-clamps, now it cannot slip anymore.
Re: Atfer Hbot, go to CoreXY. November 09, 2014 02:02PM |
Re: Atfer Hbot, go to CoreXY. November 24, 2014 04:22PM |
Re: Atfer Hbot, go to CoreXY. December 15, 2014 08:28PM |
Re: Atfer Hbot, go to CoreXY. December 21, 2014 09:14AM |
