Re: Atfer Hbot, go to CoreXY.ddd January 08, 2015 12:03PM |
zelogik
Hello,
The two bearings are not on top each other only for one reason. If the idler pulley and the motor pulley don't have the same diameter your drawing don't work well.
My design have the advantage of: You can change only the motor pulley size, have teeth idler pulley or only put "flat" bearing pulley on each idler. WITHOUT calculate/change idler/pulley axis. (don't know if anybody can understand my sentence here ....)
For your last question ... all block corner are fixed on the aluminium profile. Or maybe I don't have understood your question.
Re: Atfer Hbot, go to CoreXY. January 12, 2015 11:05PM |
Re: Atfer Hbot, go to CoreXY. February 17, 2015 04:08AM |
Re: Atfer Hbot, go to CoreXY. March 25, 2015 04:06AM |
Re: Atfer Hbot, go to CoreXY. March 25, 2015 06:26AM |
Re: Atfer Hbot, go to CoreXY. March 30, 2015 08:23AM |
Re: Atfer Hbot, go to CoreXY. March 30, 2015 11:05AM |
Re: Atfer Hbot, go to CoreXY. March 30, 2015 12:46PM |
Re: Atfer Hbot, go to CoreXY. March 30, 2015 02:03PM |
Re: Atfer Hbot, go to CoreXY. April 19, 2015 04:02AM |
Re: Atfer Hbot, go to CoreXY. May 02, 2015 08:41AM |
Re: Atfer Hbot, go to CoreXY. June 26, 2015 11:22AM |
Re: Atfer Hbot, go to CoreXY. June 26, 2015 05:59PM |
Re: Atfer Hbot, go to CoreXY. August 28, 2015 08:48AM |
Re: Atfer Hbot, go to CoreXY. October 03, 2015 06:06PM |
Re: Atfer Hbot, go to CoreXY. October 22, 2015 10:14PM |
jhelmstetter
I am looking at the all aluminum design that zelogik first posted. I am trying to get a clear understanding of the belt drive assemblies. I included my understanding of these assemblies below.
1) Does this look drawing look correct?
2) I understand the pulley P1 should be a GT2 20T with a 5mm bore, correct?
3) Are the bolts that go through the spacers marked in blue also used to connect to the T-nuts in the aluminum extrusions? It would appear that they did.
4) Are there any clear diagrams of the belt tension assembly? I see that aluminum channel is used but I haven't figured that one out.
5) Are the left and right side assemblies just mirrors of each other or are the pulley heights reversed (i.e. stepper and front pully lower on the right)?
Also, I haven't been able to find any clear pictures of the construction. Has anyone done this yet?
Re: Atfer Hbot, go to CoreXY. October 23, 2015 06:03AM |
dragondgold
jhelmstetter
Did you find how to assemble the belts?
Re: Atfer Hbot, go to CoreXY. October 31, 2015 06:26PM |
Re: Atfer Hbot, go to CoreXY. November 03, 2015 02:55PM |
Just curious if anyone has scaled this up.
Re: Atfer Hbot, go to CoreXY. November 21, 2015 05:30PM |
Re: Atfer Hbot, go to CoreXY. November 24, 2015 06:15PM |
Re: Atfer Hbot, go to CoreXY. November 27, 2015 11:14PM |
Zerginator
Hi stratmaster458,
nice variant! I think I should show my variant (work in progress), too.
You can also find my variant on github as fork of Jand's design: github/protarios
I really like your idea to vertically integrate e3d printheads. Do you mind, if I add that variant to mine?
I want to create a version, that allows for different printhead setups (e3d v6, e3d chimera and e3d kraken) depending on the users needs.
Would be great to get in contact to share some ideas how to further improve the printer.
Main Changes:
Redesign of all parts to countersunk screws (cosmetic change)
Added Screws and other details to assembly to allow for complete BOM generation out of FreeCAD
Checked availability of all parts and changed CAD to some better available parts or sizes
Added top and bottom space for electronics, potential watercooling for Kraken Hotend and to allow for fully enclosed printer compartment
Z-Axis is in progress of complete redesign to a "3 free" leadscrew variant.
Planned Changes / Additions
Add full camera/octopi support with 7" Raspi Touchscreen
Add enclusere and air management
Add e3d Kraken Hotend with watercooling system
Add Filement Feed and Spool Holders
Improve usage of print volume and stiffness of the frame
Peter
Re: Atfer Hbot, go to CoreXY. December 03, 2015 08:29AM |
Re: Atfer Hbot, go to CoreXY. December 08, 2015 07:44PM |
supernielsen
Anyone knows about this guy? [jackcleveland.name]
He is building one aswell based on this and i really dig it and would love to have a look at the files for it
Re: Atfer Hbot, go to CoreXY. December 09, 2015 04:53AM |
Re: Atfer Hbot, go to CoreXY. December 18, 2015 12:32PM |
zelogik
WOOWWWWWWWW
I leave reprap community for almost 1 year and "my" project is still alive :'-D
It's nice to see some development of my printer.
@Zerginator/stratmaster458 : Will you put some enclosure ?
so anyway as for enclosure I have not yet decided, I'm still figuring out hotend mounting, inverting the motors, and deciding on cable chain/mounting. I also need to do a bit more reworking of sdavi's XYBlocks since I'm using bushings and everything.
Re: Atfer Hbot, go to CoreXY. January 14, 2016 03:25PM |
Re: Atfer Hbot, go to CoreXY. January 15, 2016 05:38AM |
Re: Atfer Hbot, go to CoreXY. January 17, 2016 10:05PM |
gforce1
Why are you making these updates?
What is the purpose of flipping the motors?
The leadscrew i can understand.
Re: Atfer Hbot, go to CoreXY. January 24, 2016 03:14PM |
