Re: Atfer Hbot, go to CoreXY. January 24, 2016 03:14PM |
Re: Atfer Hbot, go to CoreXY. January 25, 2016 02:59PM |
Re: Atfer Hbot, go to CoreXY. January 25, 2016 03:09PM |
gforce1
The alu profiles are 20x20 mm.
The total dimension of the cube is 400x400x400 mm
Re: Atfer Hbot, go to CoreXY. January 25, 2016 03:20PM |
jand
gforce1
This is correct, but it means the horizontal profiles are 360 mm long and the vertical 400 mm
Maybe it is a good idea to have a look at the assembly file: RepRap-XY.step in the step folder in github: [github.com]
Re: Atfer Hbot, go to CoreXY. January 27, 2016 04:28PM |
Re: Atfer Hbot, go to CoreXY. February 26, 2016 07:03AM |
Re: Atfer Hbot, go to CoreXY. February 26, 2016 07:04AM |
jand
gforce1
Re: Atfer Hbot, go to CoreXY. February 26, 2016 03:00PM |
Re: Atfer Hbot, go to CoreXY. February 26, 2016 11:16PM |
gforce1
I have mounted the min-endstop for the x-axis on the leftside off the x-carrigae.
The y-min endstop is mounted on the front on the left hand side y-smooth-rod.
Home position is on the front left off the heatbed.
Re: Atfer Hbot, go to CoreXY. February 27, 2016 06:49AM |
Re: Atfer Hbot, go to CoreXY. February 27, 2016 07:11AM |
Re: Atfer Hbot, go to CoreXY. February 27, 2016 03:49PM |
Re: Atfer Hbot, go to CoreXY. February 27, 2016 10:55PM |
Re: Atfer Hbot, go to CoreXY. February 28, 2016 07:48AM |
Re: Atfer Hbot, go to CoreXY. February 28, 2016 07:58AM |
Nice, any thread that i can follow your build?Quote
gforce1
It is all printed with ABS. No modifications were made after the completion.
I am now designing a new one with a 300x300 heatbed and 300 mm in the z-direction, two(or three)belt driven leadscrews, linear guides,Dual extruder(chimera).Outher dimensions will be 500x500x500 mm.
Re: Atfer Hbot, go to CoreXY. February 28, 2016 08:07AM |
Re: Atfer Hbot, go to CoreXY. February 28, 2016 08:15AM |
Re: Atfer Hbot, go to CoreXY. February 28, 2016 02:05PM |
wendychai80
gforce1
Re: Atfer Hbot, go to CoreXY. February 28, 2016 03:02PM |
Re: Atfer Hbot, go to CoreXY. February 28, 2016 03:36PM |
Re: Atfer Hbot, go to CoreXY. February 28, 2016 08:14PM |
Re: Atfer Hbot, go to CoreXY. February 28, 2016 10:11PM |
gforce1
wendychai80
gforce1
preview:
Re: Atfer Hbot, go to CoreXY. March 05, 2016 01:01PM |
Yes thats rightQuote
wendychai80
The 2 motor above the spool is extruder motor?
I do have sometimes problems with z-wobble. i have to straighten the z-screw to fix it. It is a M8 leadscrew,Quote
wendychai80
And with the build you already complete now do you have any problem with only 1 z axis lead screw to move the bed?
Re: Atfer Hbot, go to CoreXY. March 08, 2016 11:01AM |
Re: Atfer Hbot, go to CoreXY. March 08, 2016 03:17PM |
3D_Printer_Guy
gforce1,
Nice job.
How did you build the frame? Did you tap the ends or use L shaped brackets?
Are you happy with your choice?
Thanks.
Re: Atfer Hbot, go to CoreXY. March 23, 2016 01:05AM |
gforce1
3D_Printer_Guy
gforce1,
Nice job.
Thanks.
I tapped the ends like this. I am very happy with it. It is very sollid.
btw. the printer in the picture in the previous post has not been build yet.
This one is:
Re: Atfer Hbot, go to CoreXY. March 24, 2016 03:05PM |
Re: Atfer Hbot, go to CoreXY. March 24, 2016 10:20PM |
Re: Atfer Hbot, go to CoreXY. April 05, 2016 09:59AM |
Re: Atfer Hbot, go to CoreXY. June 05, 2016 07:46AM |
