Re: Atfer Hbot, go to CoreXY.
July 24, 2014 12:49PM
Whoooooo, many people build that 'concept'. Nice to see photos of all of them.
Thanks to Ybm, sdavi and coronal11 for the photos. :-D
July 26, 2014 01:52PM
For people who have some doubt about cantilever Z axis.
Before done that I made a simulation on inventor at work. If the Z axis have a weight of 1kilos, if I add 2kilos on the printing table in the center, the both 12mm rod bend and the Z table down from 0.005mm (near each limit) to 0.08mm in the center of the rod (at 100mm). (distance on Z at opposite of 12mm Z rod).
And in conclusion I don't see problem, even makerbot, ultimaker and some stratasys us that, and each have pretty good result.
But i'm here to say that my printer is near to be finishhhhhhhhh.
It's a Cube of 400mm x 400mm x 400mm. NOTHING are out of this frame :-D (only power supply), with a printing area of 220mm x 220mm x 215mm (I can add 10mm on each axis but I don't care...)
And it's a full enclosure :-D
(And it's WIFI enabled smiling smiley)
I will post some picture quickly.
Edited 1 time(s). Last edit at 07/26/2014 01:54PM by zelogik.
July 29, 2014 08:03AM
I finally decided on the size of the exrusions It will be 360 mm horizontal and 400 mm vertical. This gives a nice 40 cm cube. I'll give the "add+20mm-Drill-Hole-and-connect-to-center-M6-opposite-profile" option a try. Although I will probably use 10mm.
I ordered the extrusions and two 12mm h6, ground and hardened shafts. Also the F624zz and LM12UU bearings are ordered.So hopefully I can build something next week.
July 29, 2014 08:19AM
@sammy66 that is the same size a my printer. Nice to see another build, keep us updated. The 20mm is actually an error. This was mend for 40mm extrusions. So 10mm should be the size to use.
Hope you have better luck with your LM12UU bearings. Mine were send twice and returned to sender for some reason. After that we agreed to cancel the order, and I had to order them somewhere else. This time it was just a few days.
ybm
July 31, 2014 07:47AM
As I am having both H-Bot and Corexy, I appreciate much more the H-Bot for the fluidity of the move.
I am using the same Marlin firmware for both. The H-bot is a Bowden 1.75 style extruder and for the Corexy I use a the same extruder as Jand, a Greg with 3mm filament.
I print much faster with the H-bot with less noise, and my print are perfect..
Ok, I am on my first print on the Corexy, so some adjustment might improve my first tough. Maybee due to the heavyness of the Greg extruder ?
Anonymous User
August 02, 2014 12:30PM
Hi guys, what is the diameter of the z rods in zelogik's setup? Is it 12mm, they look thicker than that.
August 13, 2014 08:40AM
Latest version, nearly 20% less plastic than previous version. Separated and flipped the motors, removed the tensioner bearings, so now the belts can be tensioned by sliding the motor mount along the slot. Moved the z-rods down to the next bar to gain more z height, i had 500mm sides so now i get 275mm build height.
August 15, 2014 07:49AM
sdavi
Wow that's one smart thing, gotta think of it for my next assembly.
August 16, 2014 04:46AM
marcossf
One question to all of you
Where to buy shoulder screws (4mm and 5mm shoulder diameter and 25 mm shoulder long)?? I was unable to find everywhere and also its hard to find on internet.
Marcoss try Stainless hardware from UK
Hope this helps I have used them for most of my Screws and they are very good and quick.
Doug
August 16, 2014 04:56AM
As promise some photos of the printer.
Almost finished printer :-D
Dual nozzle (one for PLA/Soft filament and the other for ABS/High temperature filament..):
Top view of the cable chain:
Rear view, need to clean cables near the ramps system smiling smiley
Full enclosure, mount & dismount = 5sec smiling smiley (thanks to magnets)
@sdavi: Nice, my first plan was to make rectangular hole ("trou oblong" in french) for fixating the motor.But it's more difficult to tight the belt with this system than a bearing like real "industrial" system.
@14thCarrot: Yes it's 12mm rod for the Z axis.
@ybm: Of course than adding an extruder on your printer make it noisier instead of a bowden system less heavier.
Edited 1 time(s). Last edit at 08/16/2014 04:57AM by zelogik.
August 16, 2014 05:08AM
Hi all Been following this thread for a while and am under way with my own build which is going to be 660x660x660 outside using 30x30 type B extrusion from Motodis,
this will give 600x600x600 internal and will use 16mm rods for the Y axis 12mm rods for the Z axis (X4 1 in each corner) and 10 mm rods for the X Axis.
Will be using a E3D Kraken 4 head hotend with Bowden Extruders Nema 23 on the Z
(due to the weight of the bed which is 500x500 sq with a 400x400x6 thick Aluminium bed heated with 20 x 12 ohm 25 watt resistors arranged to give 60 ohms which will be 240V AC Fed via a SSR)
Nema17's on all other axis and will probably use either a Duet+Duex controller or a X3 Pro
Have got some of the frame assembled and the Z frame hope to get the full frame assembled with the carriages later today and will post some Pictures then.
Doug
August 16, 2014 11:34AM
Well here is the photos of the assembled Frame and Carriages.
Think I may have to re-think the Y carriages as they take up to much room
Any Comments welcome
Got the Y carriage prob sorted simple really turn the X Carriage upside down so it Hangs from rather than sits on the rails gives me the full 400 mm + of movement to cope with all 4 extruder hot ends.
Happier now just need to square everything up. add the belt guides and motors and decide on the electronics.
Edited 1 time(s). Last edit at 08/18/2014 05:26AM by dougal1957.
August 17, 2014 01:27PM
Isn't there sag in the rods at that length?
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
August 18, 2014 02:51AM
Not in the 16mm diam Y carriage and there is so little weight on the X that the 10mm rod is pretty solid also so No. don't think there would be with 8 mm rod to be honest
But I am still not happy with the Y Carriages
Wonder if JLAND if you read this is there any chance you could modify your STL's for me to take LM16UU bearings (28mm outside diameter and 10mm dia Rods for the X spaced at 76mm.)
I am still trying to get my head around the various Cad packages
I am starting to get somewhere with Freecad but it is a slow learning curve.
Wish I could find someone local to me that uses it cos a demonstration is far better then reading tutorials!
Doug
p.s Have managed to redesign the XY Carriages using freecad so hopefully they will work (Got one side printed) have also done a X Carriage to take LM10LUU Bearings and the E3D Kraken Quad extruder hot end so not to bad off now unfortunately funds are getting low so maybe the Electronics this month so I can at least get the motions going and then the Kraken next month!
Edited 1 time(s). Last edit at 08/19/2014 11:39AM by dougal1957.
August 19, 2014 02:14PM
@Doug redesigning for ML16UU bearings is not so easy. Just making the holes bigger will not work, because there is not enough plastic to hold the bearings and the rods, So the motor-block, motor-block-top, idler-block, idler-block-top, XY-block and XY-block-top have to be changed and everything has to be carefully aligned again.
This is a lot of work. Also because FreeCAD is not very helpful here. It is probably faster to make each object from scratch rather than trying to modify them.
A 16mm smooth rod will not fit in the same position as the 8mm rod. This will give only 2 mm space between the bar and the outside of the frame. This is probably OK, but the bearing with the holder will stick outside the frame, so the position also has to change too.
If you don't mind sticking parts outside the frame you may get away with making the holes bigger in the motor-blocks and hope the the plastic around the rod is strong enough. Then you only have to redesign the XY-block. That is doable.
PS: if you have questions about how a specific part was made just ask.
Edited 1 time(s). Last edit at 08/19/2014 02:26PM by jand.
August 19, 2014 05:13PM
@Jland
Yes I realise that Now however I think I am there with this as I have managed to get things to look right (I am using 30x30 extrusion for the frame.)
I have managed to re-do the XY Blocks and they seem ok and also the X carriage to accommodate the X3D Kraken block (which is very small).
so hopefully good to go just need to make sure all the idler's are aligned correctly.
Doug
PS will keep the thread upto date with progress!
Edited 1 time(s). Last edit at 08/19/2014 05:14PM by dougal1957.
August 20, 2014 12:39AM
@doug if you made the parts in FreeCAD (or something else that can make STEP files) I can try in CAD if it will fit.
August 30, 2014 10:11PM
Hey Jand, what is the Printer Volume of your printer? 220x200x?
September 01, 2014 02:38AM
3DRapidClone
Almost, I get 210x215x165 mm (XYZ)
September 01, 2014 12:36PM
Close. So I could reason that if I increased the leadscrew by 50mm and the aluminum extrusions that it too would increase Z by 50mm? I was looking at your BOM and there are a few numbers that are off as seen here:
Edited 1 time(s). Last edit at 09/01/2014 12:37PM by 3DRapidClone.
September 01, 2014 02:12PM
3DRapidClone
Correct, to get 50mm more in Z you need to increase the 400mm extrusions and the leadscrew by 50 mm.
You also have to increase the Z smooth bars by 50mm, or you add another 360mm extrusion just below the motor blocks and move the Z-axis clamps to this extrusion.
Oeps, the values have to go down by one line, I just did the correction. Did you find any more errors in the BOM?
September 01, 2014 02:52PM
None that I can see. Do you have a list of which printed parts use which size screw? Or is it just trial and error?
September 01, 2014 03:38PM
3DRapidClone
Have a look in the second sheet in BOM.ods (M3 and M4) Which is the source for the numbers in the first sheet. It shows the number of screws/nuts/washers per part. This makes the trial and error a bit smaller
September 01, 2014 03:56PM
I am confused on its lay out. For Example B5 dictate?
4 T- nuts and then the number 8 and then 4 nuts and then 8?
September 01, 2014 04:11PM
In the middle of the sheet (Column Q) you see for instance 'Motor-block' (Q5) the number in the next column (R5) in the number of motor-blocks you need in the printer. (Two in this case)
When you want to know how many T-nuts you need for one motor block look at the left column (B5) so 4 nuts per motor-block.
The number at the right (C5) gives the total number of T-nuts for the two motor-blocks.
And so on for the next rows (parts).
The number at the bottom of the row (C18) is the total number of T-nuts needed. This number is filled in at the first sheet (Overview)
Hope this makes some sense?
September 01, 2014 04:17PM
Ah that makes more sense. Thank you very much!
September 01, 2014 11:05PM
Awesome work man, will you create a tutorial or instructions for building?
September 01, 2014 11:07PM
If you look at the src folder on Jand's github, there's a freecad model that you can dissect to figure out what goes where with the BOM.
September 02, 2014 12:45AM
Thanks, esponda.
I know i should make documentation complete. This is probably the most difficult part. BUT the most usefull to others.
September 02, 2014 12:00PM
I was lurking through this thread and noticed the August16 posting from dougal1957 where one photo shows a carriage made from a plate with a comment "Think I may have to re-think the Y carriages as they take up to much room". Possibly these may be of help to him and anybody else that finds the idea helpful.
The square cutouts, in this case in 2mm hard aluminium, have chamfers for the LM8UU bearings to rest on.
Mike
