I enabled dual extruder in config h. Set the thermocouple pins 3 and 5.
Having issues with the machine displaying temp readings erroneously. I heat extruder 1 and both show heating on the LCD although I have extruder 2 wired isconnected from the heat and the thermocouple,e is hanging outside the case.
Also the temp stabilizes 10c below set pint in Repetier, yet the auto tune runs it up to proper temp fine.
I tried adding gain 10c in the adv config and tried offset .9 and added 10. No what I do the temp just stabilizes 10c below set temp
