Using Frame for Linear Motion? August 20, 2014 06:05PM |
Re: Using Frame for Linear Motion? August 21, 2014 10:54AM |
Re: Using Frame for Linear Motion? August 23, 2014 09:08AM |
Admin Registered: 13 years ago Posts: 3,096 |
Re: Using Frame for Linear Motion? August 23, 2014 12:50PM |
Re: Using Frame for Linear Motion? September 02, 2014 10:24PM |
Re: Using Frame for Linear Motion? September 03, 2014 04:03PM |
Re: Using Frame for Linear Motion? September 04, 2014 07:30PM |
Marty56
I am planning attaching the extrusions to each other in the corners instead of relying on plastic parts to hold them together. I would use Mcmaster part number 47065T155 and then surround each corner with a printe part for the look. Do you think this would have the same kind of problems as just having printed corners?
Re: Using Frame for Linear Motion? September 29, 2014 02:33PM |
Re: Using Frame for Linear Motion? October 01, 2014 12:08PM |
cakeslob
Its not going to work very well. thats why the latest revisions are not hbot. i was building the hbot folda2 on my own as he posted the files and all the different versions. .
the plastic corner brackets make it flimsy and the y axis sliders do not have near enough rigity and to much flex. also over constrained so they just flex .
Bearing wise? I had the same problem. 8mm rods and bearings flexed too much.
My answer was, stop messing around with plastic parts and cheapo stuff. I made all aluminum parts and Im using 15mm rails and carriage proper. I made my frame super rigid, put DOWEL PINS! EVERYWHERE!
