CoreXY / First build
January 13, 2015 02:56AM
Hi smiling smiley
I've been a bit further in my 3D printer project, i thought i'd post a few pics to get advises !
Of course it's still 'WIP'. A lot of work to do on the head carriage !
So, that's my first 3D printer, and i really want to build it myself, that's part of my pleasure.
After studying different geometries, i decided to go for a coreXY implementation (because it looks such a simple and efficient solution).
The "cube" is made of 40mm square aluminium extrusion (about 1.6"), and 10mm (2/5") plywood.
- Basically the whole motors/belt/pulley system is attached to the top plywood plate.
- The "Y" rails are 8mm rods, held on the aluminum extrusions using SHF8 brackets (the flange mounted ones - not shown on my cads). This should allow to square everything perfectly.
- The "X" rail is an Hiwin MGN9 rail/bearing block. At the beginning i thinked i would use 2 rails, but they are actually so stiff that only one will be needed.
- Z will get an 8mm trapezoidal screw + delrin anti-backlash nut
- Belts are GT2 (not on CADs)
- Belt pulleys are RC helicopter parts.
- I bought a smoothieBoard to drive it.
Dimensions are 50cm x 50cm x 60cm (20"x20"x24") for a printing volume of 21x21x33cm.
Not efficient at all about dimensions grinning smiley anyway ^^
I plan to print PLA only.
Any advise appreciated ! smiling smiley
PS. please forgive my english mistakes, it's not my mother-language smiling smiley
open | download - scsh1.jpg (80.7 KB)
open | download - scsh2.jpg (64.4 KB)
open | download - scsh3.jpg (93.5 KB)
open | download - scsh4.jpg (75 KB)
open | download - scsh5.jpg (52.9 KB)
Re: CoreXY / First build
January 17, 2015 06:04PM
I updated the design, thanks to the belt path posted by gforce1 smiling smiley
It's a lot better now (well, i think grinning smiley at least everything's straight)
Waiting for my aluminium extrusions, i'll post some pictures of the build (next week i hope).
Edited 1 time(s). Last edit at 01/17/2015 06:06PM by tpra.
January 18, 2015 06:28AM
Thanks man.
I can also slide my motors to tension the belts.
The only difference is at my configuration the belts that are attached at the x-carriage are exactly in the middle.
Good luck with the build.
January 19, 2015 07:09PM
I just finished the work on plastic parts. Hope they will be printable !
Actually except for the Bowden and filament placement, everything's setup now in the CAD file
View from top :
Printed parts :
January 28, 2015 02:31PM
Work still in progress (i'm slow…)
The geometry is very good, very happy with those aluminium extrusions smiling smiley
Now i'm waiting for the printed parts to finish it !
January 28, 2015 03:15PM
Nice work m8 !
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
January 28, 2015 10:20PM
Looking great!
How are you liking that Z axis?
January 29, 2015 04:51AM
Floyd
Looking great!
Thanks smiling smiley
Actually i don't like that Z axis that much grinning smiley
The linear rails are ok (though they are loud), but metal squares are really too soft, i'll upgrade them with plywood made squares right now winking smiley
January 29, 2015 09:27AM
Ive all but got the XY on my design nailed down but im still having second thoughts about the Z axis.
I would think 12mm rods with linear bearings would be fine but until its built who knows.
January 29, 2015 10:59AM
What about 3 leadscrews drived by a single motor ?
January 29, 2015 11:31AM
Zavashier
I will be doing just this on mine and using 4 12mm linear rods (2 each side) to control my Bed (400mm x 400mm and 6mm thick aluminium on a 20x20 extrusion frame)
Doug
January 29, 2015 11:40AM
Zavashier
I thought about it, my wood planer has such a system.
But pinions and chain would be needed, that's a bit overkill imho.
Ultimakers seem to work very fine, that's why i decided to go this way for Z.
Though, those metal squares really don't fit, a plywood square will be a lot more stiff.
+ i'm using a shouting board*, so the plywood square will be more square than those chewy-squares...
* not sure of the translation... it's called a "planche à recaler" in french, the purpose is to get (really) perfect squared edges on a piece of wood with a hand plane.
Edited 1 time(s). Last edit at 01/29/2015 11:40AM by tpra.
January 29, 2015 12:32PM
tpra
Zavashier
Ah yes I am using a GT2 toothed belt around gt2 pulleys with a motor (Nema23 290oz of torque so plenty) directly driving one of my Leadscrews which in turn drives the others thru my GT2 endless belt.
Doug
January 29, 2015 02:26PM
There are a lot of machines that use a setup like yours with a single leadscrew and two guides.
January 29, 2015 03:37PM
I use one M8 leadscrew and two 12mm smooth rods with 4 linear lm-bearings.
January 29, 2015 04:46PM
You were close winking smiley the good translation is Shooting board. You don't need a chain drive. A belt drive will work smoother and quieter, with reduced maintenance through. Anyway there's a lot of maneers to move verticaly a printbed. If it stays square, no matter the way.
January 29, 2015 05:16PM
Floyd
I was wondering about that. How does the bed stay flat? Wouldn't it bend on the opposite side?
What about having the two guides at the front with the single screw in the back? Or would that cause binding issues for the guides?
Sorry for the stupid questions.
January 30, 2015 03:28AM
Kurzaa
Floyd
These cantilever effects are exactly why I use 4 smooth rods and 3 Leadscrews mind you my bed is heavy it will weigh close to 4Kg when assembled
My smooth rods are 12mm with 2 bearings on each located at each corner of the bed and I'm using 3 TR10x2 leadscrews in a triangular configuration fed with a closed loop GT2 belt and 36 tooth pulleys all driven from a single NEMA23 motor.
Doug
January 30, 2015 04:01AM
There's pros and cons on any system. Two guides is easyer to install you just need a triangle arms shape to help the bed to lay flat. The most efficient and easy way is allign all the components on a single line, the lead screw between the two guides. The force distribution is at its best that way, and it's easy to manage. Theoricaly 4 guides brings more support, but you need at last twosynchronized lead screws to distribute the movement evenly. The real problem of this system is installation. To me it's very difficult to align 4 guides strictly parallel from eachother, attented you own measuring instruments precise enough to do that. Even if your structure is stricltly square, you must use a systems allowing to set at last 2 guides and 1 lead screw in any direction, preferabily both on the same side. Then you will need a lot of time to do a proper setup. Otherhand, with 3 lead screws only, you don't need any guide. Just install 2 leadscrews strictly parallel on one side. That's easy on the same pannel. Then the last screw just need to be vertical because you won't use a captive nut on it, but just a floating one. And you're done. Through, it's less expensive than a 4 rods + 2 lead screws system, and comparable with a 2 rods + 1 screw's price, even with transmission. I measured you can move that with a single Nema17 motor about 0.5Nm because the whole system is lighter and you have less friction.
January 30, 2015 07:06AM
didn't even think about synchro belts to drive several screws ! far better than pinion/chain, indeed grinning smiley
Zavashier
Thanks Zavashier for all your answers.
That's a very important point imho.
I have very high precision tools here. Still, i don't think it would be easy to align (i mean, even with the tools, even if you know how to use them, aligning 4 guides is very hard, you have more chances to get a self-blocking system than a smooth and free movement...).
As Zavashier said, all you need to get a "non-bending" cantilever is stiff triangle arms (what i didn't do at first grinning smiley i'm correcting it, will post pics of the updated version tomorrow).
February 01, 2015 06:48AM
Updated Z axis. A lot better smiling smiley - stiff and perfectly square !
February 08, 2015 05:36PM
Work still in progress smiling smiley
Today i finished the case for electronics (12V and 24V power supplies, smoothieboard and LCD panel).
My friend just finished printing all the parts, i'll get them by 2 or 3 days, and the real fun will begin smiling smiley
CoreXY parts :
Extruder parts (Almi3k on thingiverse) :
The case (without smoothie and lcd) :
February 12, 2015 08:08PM
i just finished assembling the carriage smiling smiley
everything moves as expected. very late here, tomorrow i'll connect everything to the smoothieboard and give it a try smiling smiley
February 14, 2015 01:25PM
It moves ! smiling smiley -> video
Smoothieboard was pretty easy to configure, i'm very happy with it (still, i can't compare, i never tried anything else).
February 15, 2015 10:33AM
A bit more tests, 30.000 feedrate speed :
[www.youtube.com]
February 17, 2015 08:42AM
very cool :-)
RADDS-Shield -> Commercial [max3dshop.org]
February 22, 2015 07:50AM
Here's a video of one of the test/setup prints smiling smiley Still needs a lot of fine-tuning but i'm so happy to see it move smiling smiley just stayed watching it printing for hours grinning smiley
[www.youtube.com]
March 03, 2015 01:10PM
Hello,
This is really a nice build.
Will you upload the CAD files (either as SW or IGES) for the machine? I am about to build one myself and I would like to use your way of holding the nozzle. It is very elegant.
How did your Z plane work out?
PS. The parts your friend made for you also looks really great (!). Don't be too disappointed if you cant make something like that right away.
March 03, 2015 06:54PM
LarsK
Hello,
It prints parts, with a correct geometry, i wasn't expecting much more (well, i assume i knew building the first one would just lead me to modify it almost immediately / build another one smiling smiley )
Here's a picture of a print (fanduct problem on top, solved since that print) : [pix.slic.it]
Actually it's my first printer, and it has design flaws that i want to correct.
I already made a (huge ^^) list of what i want to make better / easier, and began to think about the next version, with lot less vitamins needed, easier fine tuning of geometry (x,y,z and bed level), better quality linear motion components (still don't know between full hiwin or a hiwin/igus mix), a bed that's 'really' flat.
It will be released open source, but i wouldn't like to release what i consider unfinished and complicated to put together (i.e. this version).
Still, if you want any part CAD of the current design, i can upload it to github if needed, just keep in mind it's a "prototype" winking smiley smiling smiley
Edited 1 time(s). Last edit at 03/03/2015 06:54PM by tpra.
March 11, 2015 09:39AM
Hello Tpra
Sorry for the late response. Eventually I have gone with my own design. I have done so for the simple reason that my "working" Delta printer is not so much working for these parts. I simply can't get it to print such solids parts as you are using. Warping and loosing contact with the bed all the time. Maybe because I am using ABS.
So I am going to go with a design that I have more confidence that I can print - And even if I can't print it, I can fabricate it in other materials.
How are your printer working out for you? Can you keep the carriage stable enough for thin wall prints?
