CoreXY and CoreXZ support for Duet electronics February 18, 2015 01:36PM |
Re: CoreXY and CoreXZ support for Duet electronics February 18, 2015 01:46PM |
Re: CoreXY and CoreXZ support for Duet electronics February 18, 2015 02:19PM |
Re: CoreXY and CoreXZ support for Duet electronics February 18, 2015 02:50PM |
Re: CoreXY and CoreXZ support for Duet electronics February 28, 2015 04:21AM |
Re: CoreXY and CoreXZ support for Duet electronics February 28, 2015 03:01PM |
| Triffid Hunter's Calibration Guide | --> X <-- Drill for new Monitor | Most important Gcode. |
Re: CoreXY and CoreXZ support for Duet electronics February 28, 2015 03:48PM |
Wurstnase
3. Repetier has two modes if you change your X and Y. But anything else is just inverting the motors.
Wurstnase
4. Headspeed/acc vs. Motorspeed/acc
Re: CoreXY and CoreXZ support for Duet electronics March 04, 2015 06:39PM |
Re: CoreXY and CoreXZ support for Duet electronics March 05, 2015 03:54AM |
Re: CoreXY and CoreXZ support for Duet electronics March 06, 2015 02:12AM |
Re: CoreXY and CoreXZ support for Duet electronics March 08, 2015 09:46AM |
os3dp
I am based in Utah, USA. Is there a US distributor?
-os3dp
Re: CoreXY and CoreXZ support for Duet electronics March 09, 2015 08:08AM |
Re: CoreXY and CoreXZ support for Duet electronics March 10, 2015 03:33PM |
Re: CoreXY and CoreXZ support for Duet electronics March 10, 2015 08:44PM |
Re: CoreXY and CoreXZ support for Duet electronics March 22, 2015 12:44PM |
Re: CoreXY and CoreXZ support for Duet electronics March 22, 2015 01:56PM |
Re: CoreXY and CoreXZ support for Duet electronics April 24, 2015 07:45AM |
Marty56
I was using pronterface originally but have now switched over to using zombiepantslol's web interface.
I'm working on calibrating my printer and trying to get some test prints done but i'm running into an unusual error when using cura. For example I've been trying to print a 1in x 1in x 1in cube. Using cura the print will start fine but my printer will continue speeding up to the point where the extruder can no longer feed filament and strips. This problem isn't happening when I use slic3r, and is not something I've run into when using Cura in the past. Any idea what could be going on?
Re: CoreXY and CoreXZ support for Duet electronics April 26, 2015 03:43PM |
