my corexy
Posted by mdcompositi
my corexy
March 04, 2015 10:38AM
Hallo guys,
this is my corexy mechanism!
I've used linear rail and slides from igus
for the rest gt2 belts and pulleys.
system works well and I've start first void tests(without extruder)
in practice happens that the layers moving, as if the belt slip !!
I've put belt tensio very well
who is the problem?
I should probably use a system with belts and pulleys T5 or the question is to be found in the parameter setting of marlin?
Edited 2 time(s). Last edit at 03/04/2015 11:59AM by mdcompositi.
Re: my corexy
March 04, 2015 11:18AM
nice and clean!
how are igus guides ?
Complimenti
Edited 1 time(s). Last edit at 03/04/2015 11:23AM by enricodare.
Enrico
Re: my corexy
March 04, 2015 03:52PM
Hi, I like your sheet metal frame and gantry. Is it home made ? How did you manage the pulleys ? Are they spinning around the bolt without bearings ?
Collective intelligence emerges when a group of people work together effectively. Prusa i3 Folger (A lot of the parts are wrong, boring !)
Re: my corexy
March 04, 2015 04:27PM
Hi
Obviously I use idler pulleys with bearings!
Smoothed for gantry and with teeth for the rest
All system is designed by me and laser cutted
Can you suggest something for My problem??
Edited 1 time(s). Last edit at 03/04/2015 04:28PM by mdcompositi.
Re: my corexy
March 05, 2015 09:10AM
Sorry, I have no awnser idea in mind for mow. As it's laser cutted, I guess you have no alignement issue. Try to check again geometry.
Edited 1 time(s). Last edit at 03/05/2015 09:11AM by Zavashier.
Re: my corexy
March 05, 2015 11:05AM
or motor, vref or some step loss
Enrico
