Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 05, 2015 03:47AM |
patrickrio
If I go 24v, do I need to do something to supply the Duet 5v or 3.3v power????? or is that already on the Duet????
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 08, 2015 03:54PM |
dc42
Duet is specified as 35V absolute maximum, Smoothieboard is specified as 12 to 24V. I don't know about the others.
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 09, 2015 05:12PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 09, 2015 05:24PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 09, 2015 07:01PM |
patrickrio
OK, I have enough electronics here to do initial setup and testing. I have optical endstops connected to the duet, I have arduino IDE installed and am connected to the board. I have the fan, heated bed, and steppers. I have not updated firmware.
Is there an installation guide for initial setup for a corexy duet?
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 09, 2015 07:41PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 10, 2015 05:21AM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 16, 2015 03:40PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 16, 2015 05:39PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 16, 2015 05:57PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 16, 2015 06:26PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 17, 2015 12:58AM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 20, 2015 07:22AM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 20, 2015 09:43AM |
patrickrio
Hi Dc42.
I understand that you had your fingers on the infra red sensor on the Ormeron 2 also. That sensor turns out to be available now and can be shipped for $15 to New York. I ordered it. I may still order yours when you have it available too. How is yours different????
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 20, 2015 11:56AM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 20, 2015 12:55PM |
patrickrio
ok, good to know. I will still be interested in your mini sensor when you do the next run... and i think i have two others interested too.
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 20, 2015 05:56PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 20, 2015 07:27PM |
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. May 21, 2015 03:41AM |
veng1
What is the accuracy and repeatability of the mini IR sensor?
veng1
Have you compared it to a capacitive bed sensor?
Re: First Build Hiwin slide CoreXY. Need help selecting electrical parts. June 01, 2015 08:47AM |
patrickrio
Hey, could you maybe post a video of the sensor operating on a delta printer? Maybe one with your leveling start-up procedure in operation? It would give a good indication of functionality....
