Would this work? April 23, 2015 09:43PM |
Re: Would this work? April 24, 2015 10:22AM |
Re: Would this work? April 24, 2015 10:41AM |
Re: Would this work? April 25, 2015 06:23PM |
Re: Would this work? April 27, 2015 08:56AM |
Re: Would this work? April 28, 2015 07:06AM |
gmh39
That design would need to be driven by 2 motors the way it is drawn. That wouldn't get rid of a level problems. It would be the same as using 2 lead screws on opposite ends of the bed; if one skips a step or binds slightly, your bed will become un-level.
If you are trying to keep the gantry as light as possible, why not just use a corexy system? The X and Y motors are static and the gantry can be made pretty light with the right design. Making the Z axis super light is kinda a moot point, be cause doesn't make large move while printing. As long as the z axis is stiff and the motor is strong enough, it should be good.
Re: Would this work? April 28, 2015 07:31AM |
Dave_robinson_022
2 stepper motors still weigh quite a bit. The idea was to achieve the advantages of a delta design with lightness and speed of effector movement without the delta math.
Re: Would this work? April 28, 2015 10:36AM |
Dave_robinson_022
gmh39
Re: Would this work? April 28, 2015 10:42AM |
