Quickhome on Corexy
Posted by ruggb
Quickhome on Corexy
May 08, 2015 11:41PM
I set quickhome in Marlin but when I use it it crashes the endstops.
If I home axis individually the endstops work fine.
There was a config I had that worked but I can't find that one.
Can anyone point me to the issue?
Re: Quickhome on Corexy
May 11, 2015 10:55AM
What and where is quickhome?
I haven't seen that before.
-a
May 11, 2015 11:07PM
the answer is - it doesn't work in Marlin 1.0.2 BUT it does work in Marlin 1.0.3 dev. Unfortunately, I can't set EXTRUDERS 2 and get it to step except to home.
May 11, 2015 11:13PM
it homes both X & Y at the same time (a diagonal home) to speed things up. U must uncomment it - it is in configuration_adv.h
but it doesn't work in 1.0.2
It does work in 1.0.3 dev - but it appears that 2 extruders doesn't work.
1.0.3 dev has some major reformatting work. I think they r trying to get all the variable into the 2 config files.
So if u have modified other files u will need to relearn some stuff - where things r.
Edited 1 time(s). Last edit at 05/11/2015 11:14PM by ruggb.
May 12, 2015 08:30AM
Thanks for the info. Interesting.
I'm sure they'll fix it sooner or later. Marlin seems to change every day.
Did you raise it as an issue on Marlins Github page?
-a
May 12, 2015 10:17PM
actually, it is the documentation that needs work. The issue was i selected the wrong motherboard but there was no info in the dev version config file.
It is a large reorganization job. I think they r trying to put all variables in the config file but other things r moving to strange places.
May 19, 2015 11:49PM
got it, thx
