Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 23, 2015 01:57PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 23, 2015 02:19PM |
patrickrio
I made a first draft of a Duet case designed for my application... combined features of a few and modded a bit. I have attached it so anyone can use it.
It has a finger hole so you can hit the reset button, has big vents, and is made so the clear cover will slide in from the top. I elected to keep the erase button harder to hit, and you will need to remove the clear cover to get to it.
This case will need to be modified again when my fan arrives, and I think I need to put a bit more ventilation space below the board also. I will keep everyone posted.
a few questions:
1. what is the name of the connectors used on the Duet, and where can I buy them? I would really like to be using the lock tabs....
2. I want to increase the max acceleration rates in the config file... but I really don't know what is appropriate. linearly moving mass in the xy plane is only 150g and there is very little friction, so I should be able to accelerate a lot faster... What suggestions do you have for max rates?? I just have no experience with this...
almost through my first KG of filament.
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 23, 2015 03:23PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 23, 2015 04:11PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 23, 2015 04:22PM |
patrickrio
I see the connectors listed several ways.. I think they are all the same:
1. KK-100 or 0.100 inches
2. KK-254 or 2.54mm
3. KK 2.5mm
4. KK 0.98 inches
I think that these are all the same connector. Please confirm.
also, I guess I need a crimper tool too... any suggestions on good, inexpensive crimpers available in US??
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 23, 2015 04:51PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 23, 2015 07:04PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 24, 2015 02:53AM |
patrickrio
connectors and crimper ordered.
any suggestions on acceleration limits??
any suggestions on why the printer has the weird retracts on print pause???
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? September 24, 2015 07:46PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? September 24, 2015 11:25PM |
