CoreXy is only moving diagonally
Posted by gmh39
August 25, 2015 06:00PM
So Im setting up my CoreXY printer using Marlin and Repetier Host, and no matter the plug configuration I use for the motors, the carriage only moves in diagonally. I have tried every configuration:
X                        Y
M1 forward          M2 forward
M1 forward          M2 backward
M1 backward       M2 forward
M1 backward       M2 backward
M2 forward          M1 forward
M2 forward          M1 backward
M2 backward       M1 forward
M2 backward       M1 backward
Is there something in the firmware I should try?
Also, one of my motors is mounted upside down because of how I have the printer designed. This may affect how the motors work, but I doubt it is a deal breaker.
greghoge.com
HUGE 3D PRINTER PARTS SALE!!!
Re: CoreXy is only moving diagonally
August 25, 2015 06:15PM
gmh39:
You will need to turn on CoreXY in the Marlin firmware.
-os3dp
August 25, 2015 07:36PM
I had the same problem. My issue turned out to be my ramps board and adrino were not pushed together tight enough.
August 25, 2015 08:02PM
My corexy is turned on and my Ramps and Arduino are pressed firmly together.
greghoge.com
August 25, 2015 08:53PM
Try and swap the motor connections to make sure the other motor and controller is good.
August 26, 2015 01:42AM
If it's only moving diagonally, that means only a single motor is turning. One of your motors or drivers is probably bad.
August 26, 2015 11:24AM
Lol. Figured it out. One of the motors wasn't plugged in...
greghoge.com
