Re: G&C Printer September 28, 2015 05:51AM |
David J
I may be using a different method for mounting the E3Dv6, but I'm not sure yet. The setup on my delta works very well, so I will probably try to take the whole thing over to this printer. Your design gives a lot of flexibility, which helps a lot.
Re: G&C Printer September 28, 2015 06:16AM |
Re: G&C Printer September 28, 2015 03:09PM |
Re: G&C Printer September 28, 2015 03:20PM |
Re: G&C Printer September 28, 2015 03:40PM |
Re: G&C Printer September 29, 2015 06:09AM |
Re: G&C Printer September 29, 2015 07:06AM |
David J
Hmm... those LED strips are 7W - maybe I'll print that piece in ABS...
Using acrylic or aluminium sheet is way better. I have first try to use black acrylic sheet but i not found any place where it was possible to cut with an laser. And is a more expensive solution.Quote
David J
I'm not sure I'll print the panels as they will take a lot of time and filament; I'll probably cut them out of plastic or aluminium sheet.
Yes, each idler is made of 2 flanged bearings.Quote
David J
Am I right in thinking that each idler is made up of 2 of the bearings, with flanges to the outside?
No. The 2 bearings have the outside wall in direct contact in the middle. I use 2 M4 washers to force that only the inside of the bearing is in contact with the plastic piece.Quote
David J
Do you put a washer between each bearing, to stop them binding?
is a simple 608ZZ. The piece is important to cut the vibrations of the Z when rotation in high speed. I have added 1,5 mm to this piece, but i not sure if is the correct dimension. this error have happened because the aluminum SH12A (http://www.ebay.com/itm/300553708067) do not have the dimensions i was expecting. You can add an second piece between the coupler and the lead screw, you only need to put the back 2020 bar a little more above. this bar bar is put where to support two filament support when the printer will go dual extuder.Quote
David J
What size is the bearing that holds the bottom of the Z axis screw? (it's not in the BOM)
in my case (repetier firmware) X is the left motor, Y the right.Quote
David J
To save me the effort of working it out - which I won't be able to do until the belts are fitted - which motor is X and which is Y?
Re: G&C Printer September 29, 2015 10:53AM |
Re: G&C Printer September 29, 2015 11:21AM |
Re: G&C Printer October 01, 2015 06:26AM |
Re: G&C Printer October 01, 2015 07:13AM |
Re: G&C Printer October 01, 2015 07:17AM |
Re: G&C Printer October 01, 2015 07:55AM |
Re: G&C Printer October 01, 2015 08:49AM |
Re: G&C Printer October 03, 2015 07:39AM |
Re: G&C Printer October 03, 2015 01:01PM |
Re: G&C Printer October 03, 2015 01:43PM |
Re: G&C Printer October 03, 2015 02:01PM |
Re: G&C Printer October 03, 2015 02:23PM |
Re: G&C Printer October 03, 2015 04:32PM |
Re: G&C Printer October 03, 2015 04:55PM |
David J
should the right-rear motor mount have a movable idler to tension the belt?
Re: G&C Printer October 03, 2015 05:02PM |
Re: G&C Printer October 03, 2015 05:18PM |
David J
I'm using F624ZZ everywhere - should work OK (he said, hopefully).
Re: G&C Printer October 03, 2015 05:28PM |
Re: G&C Printer October 03, 2015 05:49PM |
Re: G&C Printer October 04, 2015 05:14AM |
Re: G&C Printer October 04, 2015 07:54AM |
Re: G&C Printer October 04, 2015 02:54PM |
Re: G&C Printer October 04, 2015 04:22PM |
