Re: G&C Printer October 11, 2015 05:10PM |
Re: G&C Printer October 12, 2015 11:46AM |
Re: G&C Printer October 12, 2015 01:41PM |
Re: G&C Printer October 15, 2015 05:38AM |
Re: G&C Printer October 15, 2015 06:32AM |
Re: G&C Printer October 15, 2015 07:16AM |
Re: G&C Printer October 15, 2015 08:36AM |
Re: G&C Printer October 15, 2015 08:49AM |
Re: G&C Printer October 16, 2015 05:28AM |
Re: G&C Printer October 16, 2015 07:52AM |
Re: G&C Printer October 17, 2015 10:37AM |
Re: G&C Printer October 17, 2015 12:20PM |
Re: G&C Printer October 17, 2015 04:11PM |
Re: G&C Printer October 19, 2015 05:43AM |
Re: G&C Printer October 19, 2015 06:23AM |
Re: G&C Printer October 19, 2015 07:20AM |
dc42
1. If you connect the Duet to your home network, then you can use any tablet to control the printer over your wifi. If the Duet is too far away to connect to your router, then you can use an wifi to Ethernet bridge such as the WR710N.
2. Are you aware of the PanelDue touch screen control panel for Duet electronics? See [miscsolutions.wordpress.com] for details. I manufacture and sell the display controller board, and you add your own compatible 4.3, 5 or 7 inch display panel. Or you can buy the complete kit form T3P3.
dc42
3. If the issue is providing 5V power to a tablet, you can get this from the Duet electronics board if you are using the on-board 5V switching regulator.
Re: G&C Printer October 19, 2015 08:10AM |
Re: G&C Printer October 19, 2015 08:30AM |
Re: G&C Printer October 19, 2015 08:57AM |
Re: G&C Printer October 22, 2015 05:29AM |
Re: G&C Printer October 22, 2015 07:10AM |
Re: G&C Printer October 27, 2015 02:48PM |
Re: G&C Printer October 27, 2015 04:25PM |
Re: G&C Printer October 27, 2015 05:33PM |
Re: G&C Printer October 28, 2015 06:58AM |
Re: G&C Printer October 28, 2015 02:31PM |
Re: G&C Printer October 29, 2015 11:23AM |
Re: G&C Printer October 29, 2015 03:11PM |
Re: G&C Printer October 30, 2015 05:34AM |
Re: G&C Printer October 30, 2015 06:28AM |
David J
I came across one problem when doing the belts, which you might like to consider: the pieces that hold the belts to the X carriage have a peg in the middle that the belt goes around, but while adjusting the belt tension the peg broke on a couple of the pieces after putting the belt in and taking it out again a few times. There may be 2 ways of fixing this - make the groove wider, so it's easier to get the belt in (but the problem may be that my printer made them a bit 'fat' anyway), or make the peg much larger so it will be stronger. In the end it wasn't much of a problem, as I wrapped the belt around the broken-off peg and pushed it back into the hole, and it's now very secure!
