CoreXY for bed instead of extruder(s), for small printer? August 29, 2015 04:48PM |
Re: CoreXY for bed instead of extruder(s), for small printer? August 31, 2015 03:39AM |
Re: CoreXY for bed instead of extruder(s), for small printer? August 31, 2015 05:50AM |
Re: CoreXY for bed instead of extruder(s), for small printer? August 31, 2015 07:07AM |
Re: CoreXY for bed instead of extruder(s), for small printer? August 31, 2015 10:20AM |
Re: CoreXY for bed instead of extruder(s), for small printer? August 31, 2015 01:12PM |
J-Max
Look at the investment.
That mini printer works fine with acrylic, for its dimensions.
I mean much better than a Prusa I3 acrylic,
with its building volume more than 4 times larger !
But to have a first contact with 3D printing,
with a plug and play machine around 150€, it's not a bad idea.
You can keep it as a secondary printer or sell it easily.
I mean you can't design a proper printer if you did not experience 3D printing for a while.
J-Max
Geared or not, bowden and direct drive systems have pro and cons.
None are perfect. I experimented both, and I prefer bowdens,
because there's less influence of the drive system and filament traction on the printhead,
and the moving parts are lightweight, and that allows faster acceleration.
Once a printer is well set up, you will be looking for speed.
J-Max
it will be difficult to find a better system than the CoreXY for a 3D printer.
Re: CoreXY for bed instead of extruder(s), for small printer? August 31, 2015 01:20PM |
LarsK
Concerning the topic - Moving the bed - I think it is an interesting idea and worth investigating. I think maybe it is more attractive for a CoreXY CNC mill. If you just want more extruders then I think you are better off sticking to the hotend moving CoreXY and just upping the overall quality of the build.
LarsK
Occasionally some dreamer comes along who wants to make an all-in-one 3d machine (multi color 3d Printer, CNC, Laser, plotter, coffee maker). If such a machine should be made, I think coreXY with the bed moving would be the way to go.
Re: CoreXY for bed instead of extruder(s), for small printer? September 01, 2015 04:39AM |
Re: CoreXY for bed instead of extruder(s), for small printer? September 01, 2015 07:53AM |
J-Max
christian, the Corexy belt system is a push-pull loop transmission.
What you could lose at a end will be compensaded at the other end.
Movements are assumed simulteaneously by 2 belts too.
There's max extension values for each belt, that's true.
But, that does not means a belt is so flexible.
That value is max extension before the belt brakes.
That means you should overtake the admissible load for the belt.
For a reprap, what are we talking about ? 0.2Nm ?
The load on a 3D printer is definitely negligeable, even for a GT2 belt.
There's different belt quality, but a low quality armoured belt already stands a lot.
To be confident you can even upgrade to a fiberglass armoured belt too, its no big deal.
But it ain't necessarary so.
Re: CoreXY for bed instead of extruder(s), for small printer? September 01, 2015 08:51AM |
Re: CoreXY for bed instead of extruder(s), for small printer? September 01, 2015 09:14AM |
J-Max
Seems like you need manufacturer's data to make up your mind.
So just ask your provider or a manufacturer.
Re: CoreXY for bed instead of extruder(s), for small printer? October 06, 2015 10:29PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 07, 2015 01:24PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 07, 2015 03:36PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 08, 2015 08:09AM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 08, 2015 03:57PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 08, 2015 05:05PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 09, 2015 08:25AM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 09, 2015 01:00PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 09, 2015 01:33PM |
J-Max
Un nordiste... Bon, on te garde quand même... ^^
J-Max
Christian, don't be affraid about the belts. Belts are not elastic stuff.
Stretch values of 0,4% max are in extreme issues, just before beaking.
J-Max
A GT2 6mm quality belt allows 120Nm !
You won't get the quarter of that on your printer, even with preload or friction.
J-Max
You should consider the V-slot technology too.
That guides are quiet and very sturdy too.
Re: CoreXY for bed instead of extruder(s), for small printer? October 11, 2015 03:18PM |
I realy don't know. Maybe it's because of motion and speed while N is for a still mass ?Quote
Ryan_M
Hey guys, I'm not an engineer or anything so I'm hoping you can clear something up for me as I'm following along... Why are belt tensions being expressed as a torque value in Nm? Wouldn't a belt under tension strictly be a one dimensional force that should just be in N? Sorry if this is a dumb question.
Re: CoreXY for bed instead of extruder(s), for small printer? October 11, 2015 04:15PM |
J-Max
Christian, what precision would you expect ?
Re: CoreXY for bed instead of extruder(s), for small printer? October 12, 2015 10:49AM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 12, 2015 04:50PM |
J-Max
Christian, you can't reach a 10µ precision with any FDM printer IMHO.
The best you can expect is +-150µ. You'd rather look at SLA or DLP printers.
J-Max
A single 300mm C0 ballscrew is more expensive than most of the reprap kits.
Re: CoreXY for bed instead of extruder(s), for small printer? October 12, 2015 04:55PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 12, 2015 05:10PM |
dc42
You can often get better resolution than 150um in the Z direction from an FDM printer, but not usually in the X and Y directions, because the extrusion width is typically about 400um.
Re: CoreXY for bed instead of extruder(s), for small printer? October 12, 2015 05:30PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 12, 2015 05:36PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 12, 2015 06:46PM |
cristian
dc42
The problem for me is not just the resolution. It is true that details smaller than 400µ cannot be printed with a standard nozzle, but if the positioning system allowed a precision of 10µ along X and Y, then a vertical wall printed at 50µ layer height would really look good, even if the layer width is 400µ. Conversely, with a precision ( ~= repeatability) of 150µ, a vertical wall printed at 50µ looks horrible independently of the chosen layer width I think.
Re: CoreXY for bed instead of extruder(s), for small printer? October 13, 2015 07:12AM |
J-Max
You can't reach your model's dimensions within 10µ with a FDM printer.
J-Max
It's not depending of the mecanics, but of the fused filament technology itself.
There's an aleatory factor with fused filament.
You need to squeege the filament on the previous layer to make a good bond.
So, if you have a 250µ nozzle maybe your filament path will be +-275µ
depending of various factors, like speed, vibrations, heat variation,
fused filament expansion, and many little random parameters.
J-Max
Just a question Christian, what is that printer for ?
