Re: CoreXY for bed instead of extruder(s), for small printer? October 13, 2015 07:40AM |
dc42
I have no experience of CoreXY designs, but I am guessing that stretch in the long belts may be a limiting factor. If it isn't, or it can be overcome, then I think you should be able to achieve better than 50um resolution (but not accuracy) in the XY plane. You may need to use 0.9deg/step motors to get higher incremental torque, and small enough pulleys to get a high steps/mm factor.
Re: CoreXY for bed instead of extruder(s), for small printer? October 13, 2015 09:53AM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 13, 2015 05:25PM |
J-Max
A DLP printer (resin printer with video projector instead of SLA -laser)
can be achieved at reasonable price, because there's only one axis, one guide.
You just need to find one way to project any UV image.
There's a lot of inexpensive examples on the DIY community.
Definitely, for jewelry or precision figurines, you want a resin printer.
J-Max
Fluctuations are mostly stable, you can feel them by the touch but you can't eyeball it.
But it exists. IMHO, to have some very precise mecanics won't help over 100µ.
You won't notice any improvement because of the filament thing.
J-Max
Some people believes in a heavy structures and precise guides for 3D printing.
For example the_digital_dentist's son of megamax..
His machine is very good and pretty interesting too.
Otherhand, some light machine can achieve close results with less precise/expensive components.
Please note, the son of megamax printer don't reach 50µ precision,
even if that eperienced repraper has come as far as possible with components/expenses.
Re: CoreXY for bed instead of extruder(s), for small printer? October 15, 2015 06:24AM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 15, 2015 07:47AM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 15, 2015 01:14PM |
Edvardas
Have you considered a material to make a bed platform of? I tried to google hoping to find plenty of information on people using all kind of different materials on cartesian printers to lighten Y axis but came with nothing.
Aluminium-foam sandwich (dibond) came to my mind as it is light and stiff.
J-Max
The printing bed don't need to be light on a CoreXY printer.
Re: CoreXY for bed instead of extruder(s), for small printer? October 16, 2015 05:37PM |
Re: CoreXY for bed instead of extruder(s), for small printer? October 16, 2015 06:11PM |
Re: CoreXY for bed instead of extruder(s), for small printer? November 06, 2015 11:46AM |
Re: CoreXY for bed instead of extruder(s), for small printer? November 11, 2015 01:00PM |
cristian
For a printer with a small printing area (for example 100x100mm) and more than one extruder, in your opinion would it make sense to have a coreXY to move the small bed and have the (direct) extruders lifted only vertically?
Re: CoreXY for bed instead of extruder(s), for small printer? November 11, 2015 10:41PM |
Re: CoreXY for bed instead of extruder(s), for small printer? November 12, 2015 06:22AM |
bunbun
Main problem of moving bed instead of moving extruder is space efficiency. When you design a printer with moving bed, you need at least 4X bed surface area for bed movement.
Let say you designing a printer with print size 100X100X100 by moving bed. Then your printer size will be at least 250X250X250 (bed movement plus bearing, motor, etc.).
In same case, if you design it in moving extruder mode. Then your printer size can be controlled in 200X200X200.
If the printer be enlarged to a bigger size, the different will be enlarged dramatically.
Re: CoreXY for bed instead of extruder(s), for small printer? November 12, 2015 10:45PM |
Re: CoreXY for bed instead of extruder(s), for small printer? November 15, 2015 07:43AM |
the_digital_dentist
I think that some of you guys are confusing precision, minimum feature size, minimum step size, resolution, and accuracy.
VincentM
cristian
Not a CoreXY, but a Delta:
[www.diyouware.com]
bunbun
As your title CoreXY for bed instead of extruder, for SMALL PRINTER. For me, it is talking about designing a small printer that in moving bed. Not a moving small bed printer.
Re: CoreXY for bed instead of extruder(s), for small printer? November 15, 2015 08:24AM |
Re: CoreXY for bed instead of extruder(s), for small printer? November 15, 2015 09:38AM |
Re: CoreXY for bed instead of extruder(s), for small printer? November 15, 2015 11:27AM |
Re: CoreXY for bed instead of extruder(s), for small printer? November 15, 2015 05:14PM |
Re: CoreXY for bed instead of extruder(s), for small printer? January 08, 2016 01:05PM |
