Corexy help
Posted by Taz-dig
Corexy help
September 11, 2015 09:36PM
I am about to start my corexy printer. One thing I do not km now is how to set the steps for x and y I have a 1.8 deg stepper and I am driving the printer with 1/16 steps. I don't have a belt, I have spectra line running on the printer. So how would I calculate the steps per drive on these two motors?
Digs
Re: Corexy help
September 11, 2015 10:33PM
You can always just start with 90 step / mm and then you ask it to move and measure how much it moved.
Say you asked it to move 100 mm and it moved 75mm then you do:
New steps pr mm= 90 * 100/75
As per the equation:
NEW_STEPS_PR_MM = OLD_STEPS_PR_MM * IDEAL_MOVE / REAL_MOVE
Alternatively, you need to measure the diameter of the pulley with the spectra-line and calculate the circumference ( O ) . Then you say: 16 * 360 / (O* 1.8)
The equation being: NEW_STEPS_PR_MM = MICROSTEPS * 360 / ( CIRCUMFERENCE * DEG_PR_STEP)
Re: Corexy help
September 12, 2015 11:45AM
Thanks Larsk,
I made the change with calculating the steps based in the diameter for start, it sounds a lot better and runs smooth. Now to calibrate and begin the fun.
