FuseBox ~$300 CoreXY Printer September 12, 2015 11:28PM |
. The total cost, including filament for the plastic parts, is slightly under $300.
Re: FuseBox ~$300 CoreXY Printer September 13, 2015 11:28PM |
Re: FuseBox ~$300 CoreXY Printer September 14, 2015 04:13AM |
Re: FuseBox ~$300 CoreXY Printer September 14, 2015 11:07AM |
wfcook
What model of coldend is that? I am intriqued by the binder clip spring mechanism.
Re: FuseBox ~$300 CoreXY Printer September 14, 2015 12:48PM |
Re: FuseBox ~$300 CoreXY Printer September 14, 2015 02:39PM |
Re: FuseBox ~$300 CoreXY Printer September 20, 2015 08:18PM |
Re: FuseBox ~$300 CoreXY Printer November 09, 2015 01:10PM |
Re: FuseBox ~$300 CoreXY Printer November 19, 2015 06:43PM |
Re: FuseBox ~$300 CoreXY Printer November 20, 2015 11:11PM |
Re: FuseBox ~$300 CoreXY Printer November 21, 2015 03:43PM |
AlexY
Thanks for the positive feedback!
For the future, I plan on making a 2020 extrusion version of the FuseBox using metal corner brackets instead, which should make the frame super rigid. There's still a bit of frame wobble on the x-axis since it's braced with plastic parts only.
BTW, any suggestions for increasing x-axis rigidity? I can't put a cross brace on the front because it would get in the way when removing prints, and the z-rods prevent a cross brace in the back as well.
Re: FuseBox ~$300 CoreXY Printer November 22, 2015 06:29AM |
Re: FuseBox ~$300 CoreXY Printer November 28, 2015 10:47PM |
Re: FuseBox ~$300 CoreXY Printer December 07, 2015 09:58AM |
Re: FuseBox ~$300 CoreXY Printer December 07, 2015 12:05PM |
Re: FuseBox ~$300 CoreXY Printer December 07, 2015 04:50PM |
Re: FuseBox ~$300 CoreXY Printer December 08, 2015 07:20PM |
Re: FuseBox ~$300 CoreXY Printer December 08, 2015 09:45PM |
Re: FuseBox ~$300 CoreXY Printer December 10, 2015 09:22AM |
janpenguin
@AlexY
Yours look great.
Have you thought about using square metal brakets to join aluminium profiles?
There are L-shape and triangle-shape.
Re: FuseBox ~$300 CoreXY Printer December 12, 2015 12:35PM |
Re: FuseBox ~$300 CoreXY Printer December 13, 2015 12:37AM |
Re: FuseBox ~$300 CoreXY Printer December 15, 2015 06:03AM |
Re: FuseBox ~$300 CoreXY Printer December 17, 2015 09:17AM |
Re: FuseBox ~$300 CoreXY Printer December 28, 2015 10:13PM |
Re: FuseBox ~$300 CoreXY Printer December 29, 2015 02:53AM |
Regarding the Z-axis.Quote
AlexY
I ended up finding some metal corner brackets for 1515 extrusions on Misumi so I ordered some of those. I'll try them out when they arrive and see if they help rigidity.
Also, does anyone have recommendations for a better Z-axis coupling method? The metal flex coupler allows the bed to bounce up and down a bit, and also doesn't hold the threaded rod exactly in the center.
Re: FuseBox ~$300 CoreXY Printer December 29, 2015 12:27PM |
Re: FuseBox ~$300 CoreXY Printer December 30, 2015 04:33AM |
The nut/coupler really shouldn't have any noticeable horizontal movement. None of mine does.Quote
AlexY
Yeah, I guess the bouncing shouldn't be that much of an issue, but my main concern is the threaded rod not being centered in the coupler; that might be the cause of the slight wobble in prints.
Re: FuseBox ~$300 CoreXY Printer December 30, 2015 05:08AM |
AlexY
Re: FuseBox ~$300 CoreXY Printer December 31, 2015 08:22PM |
Re: FuseBox ~$300 CoreXY Printer December 31, 2015 08:26PM |
