Re: FuseBox ~$300 CoreXY Printer January 01, 2016 08:52PM |
Re: FuseBox ~$300 CoreXY Printer January 01, 2016 08:53PM |
Re: FuseBox ~$300 CoreXY Printer January 02, 2016 05:33PM |
Re: FuseBox ~$300 CoreXY Printer January 03, 2016 04:54AM |
I had the same issue when making the UM2 aluminium clone as my "source" printer was only 10x10cm. I used Netfab Basic to split the larger parts. Mainly for the Z-axis. Worked perfectly for meQuote
Culain
Hi Alexy,
i recently stumbled upon your coreXY design printer.
Looks very solid to me. I think i'm gonna build one myself.
i just will be unable to print the top and bottom z-axis bracket since it is >190mm (my maximum print radius of my delta printer).
I guess i will design some smaller ones or maybe just split them up.
Looking forward to build it
Edit:
You think it is possible to get the printer files for 2020 extrusions?
Re: FuseBox ~$300 CoreXY Printer January 04, 2016 04:20AM |
Re: FuseBox ~$300 CoreXY Printer January 04, 2016 04:31AM |
I'm Danish, so I know the 1515 is hard to find. You should buy from motedis.de - at least their profiles are very cheap.Quote
Culain
Yeah well,
splitting isn't an issue.
The bigger problem is, that 1515 aluminum extrusions are not that easy to get in Germany.
So I'm about to change everything to fit 2020 aluminums with M4 screws. May take a while since I'm not that familiar with sketchup
Re: FuseBox ~$300 CoreXY Printer January 04, 2016 04:39AM |
Re: FuseBox ~$300 CoreXY Printer January 04, 2016 07:21PM |
Re: FuseBox ~$300 CoreXY Printer January 05, 2016 05:32PM |
Re: FuseBox ~$300 CoreXY Printer January 05, 2016 05:33PM |
Re: FuseBox ~$300 CoreXY Printer January 05, 2016 05:35PM |
AlexY
Try upping your perimeter thickness, as well as possibly increasing your print temperature a bit. I haven't had any issues with those parts breaking on my printer.
Re: FuseBox ~$300 CoreXY Printer January 05, 2016 05:52PM |
Re: FuseBox ~$300 CoreXY Printer January 05, 2016 07:01PM |
Culain
yeah shit... i was just done modifying it myself and upload it to thingiverse...
Edit: Here it is [www.thingiverse.com]
Re: FuseBox ~$300 CoreXY Printer January 06, 2016 09:06AM |
Re: FuseBox ~$300 CoreXY Printer January 06, 2016 05:36PM |
Re: FuseBox ~$300 CoreXY Printer January 07, 2016 07:15AM |
Re: FuseBox ~$300 CoreXY Printer January 08, 2016 03:48PM |
Re: FuseBox ~$300 CoreXY Printer January 16, 2016 01:05AM |
Re: FuseBox ~$300 CoreXY Printer January 16, 2016 04:09AM |
yes. Try checking if your gantries (the brackets holding up the bearings for the rods) are still in good working conditions.Quote
Brownievtec
I'm going crazy. I was getting awesome prints now all of the sudden I'm getting later shifts. I turned the speed down re adjusted the stepper drivers and make sure all belts were tight.
Anyone else have any ideas
Re: FuseBox ~$300 CoreXY Printer January 17, 2016 06:59PM |
Re: FuseBox ~$300 CoreXY Printer January 28, 2016 07:48PM |
Re: FuseBox ~$300 CoreXY Printer January 29, 2016 03:10PM |
Re: FuseBox ~$300 CoreXY Printer January 31, 2016 06:25AM |
Re: FuseBox ~$300 CoreXY Printer January 31, 2016 02:07PM |
Re: FuseBox ~$300 CoreXY Printer February 02, 2016 08:05PM |
Culain
Yeah well,
Re: FuseBox ~$300 CoreXY Printer February 04, 2016 05:55PM |
Re: FuseBox ~$300 CoreXY Printer February 08, 2016 08:51AM |
Re: FuseBox ~$300 CoreXY Printer February 10, 2016 06:40PM |
rmrf
Ax
Just a quick one, Misumi EU is based in Frankfurt. So you can actually order direct. I basically did that for 2020s.
Did you buy through company? Misumi EU seem only to work with companies.
Re: FuseBox ~$300 CoreXY Printer February 15, 2016 12:06AM |
Re: FuseBox ~$300 CoreXY Printer February 16, 2016 02:08PM |
Ax
rmrf
Ax
Ah yeah, that's a point, I'm self employed and have a UK Limited Company, didn't even think of that, it's just automatic when buying printing stuff to put it on the Business. If you're in the UK, the next best place for 2020 extrusion is E3D at 1p/mm ex VAT it's not too bad.
Also, the build has begun!
