Re: FuseBox ~$300 CoreXY Printer March 23, 2016 09:23AM |
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 09:29AM |
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 09:39AM |
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 09:52AM |
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 10:00AM |
One of the nice things about the 15x15 extrusions is they can take regular hex m3 nuts!Quote
godefroi
And, here's one already. Do I need the fancy square nuts from MiSUMi, or can I buy cheap hex M3 nuts from just about anywhere?
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 10:01AM |
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 10:20AM |
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 10:42AM |
godefroi
AlexY mentions in the comments on Thingiverse that he's using 76 oz-in steppers. Judging by what's commonly available (say, at robotdigg), that seems pretty high. They, for example, have:
Should I go for the 92 oz-in steppers (they're only $1 more than the 62 oz-in), or should I stick with the 62 oz-in? Also, is there any advantage to using 400 steps/rev steppers, or would that just slow everything down by half? They're only $0.10 more in the 62 oz-in size. One of the commenters on Thingiverse mentioned they used the 400 spr stepper for the extruder, is there an advantage to be had there?
- 40 oz-in (34mm body)
- 57 oz-in (40mm body)
- 62 oz-in (48mm body)
- 92 oz-in (60mm body, labeled "high torque")
Also, flat or round shaft, or does it not matter?
Re: FuseBox ~$300 CoreXY Printer March 23, 2016 10:56AM |
redesigned bowden direct drive to E3D v6 3mm March 24, 2016 03:34PM |
Re: FuseBox ~$300 CoreXY Printer March 26, 2016 08:50AM |
godefroi
Re: FuseBox ~$300 CoreXY Printer March 26, 2016 08:53AM |
Re: FuseBox ~$300 CoreXY Printer March 26, 2016 09:19AM |
pen25
one thing i noticed about the carriage. i have printed it a couple times. and had a friend print it. seems the belts dont fit in the slots. i have modified it and about to print it to see how well it works. i measured my belts and they were wider then what is designed on the stl. if it works i will upload it. I have also modified the y rod ends as they werent holding up. how did you all deal with the belts? and did anyone else have problems with the y rods?
Re: FuseBox ~$300 CoreXY Printer March 26, 2016 09:43AM |
pen25
Re: FuseBox ~$300 CoreXY Printer March 26, 2016 04:16PM |
pen25
Re: FuseBox ~$300 CoreXY Printer March 26, 2016 07:23PM |
Re: FuseBox ~$300 CoreXY Printer March 27, 2016 06:23AM |
pen25
well the gap is 1.2mm and only .7mm from tooth to edge on the original design. the one i edited is 1.8mm edge to edge and 1.3mm tooth to edge. i just printed it and the belts fit fine. and they are the 6mm belts specified in the bom. my belt measures 1.8mm on the calipers.and i just finished printing this new one and belts fit perfect. but those darn ears are curling up on me and breaking off. one more thing to mess with.
Re: FuseBox ~$300 CoreXY Printer March 27, 2016 08:43PM |
pen25
git clone [hands.com]
Re: FuseBox ~$300 CoreXY Printer March 28, 2016 07:17PM |
lkcl
pen25
ok if you're referring to the first layer not sticking, such that the fine detail of this design's parts are curling up, then may i suggest that you add a "brim" of around 5mm. i also use a heated bed *and* unscented hairspray. i'm developing a libre eco-conscious laptop: some of the parts are 230mm x 12 x 16mm so curling was a serious problem that i absolutely had to solve. brim. heat. hairspray. bye bye problem.
anyway, apologies for bringing it up: if you're not familiar with why it's... well, first you should google and read the "father sylvester response", and substitute for the proprietary software wherever you see "microsoft word" replace it with "whatever proprietary software you're using", and wherever you see "RTF" or "Text" replace it with "STL" or "DXF" or something. being blunt and direct, pen25, if you don't mind me being so, it's basically really rude to assume that the person you're talking to wishes to spend *their* personal funds on (a) proprietary software (b) proprietary operating systems (c) a replacement computer *capable* of running both (a) and (b).
anyway, i thought you might appreciate knowing that i really couldn't stand the thought of hacking the carriage belt traps even more with an xacto knife, so i redesigned them [in pyopenscad], and i came up with a scheme which uses an M2 5mm pozi screw and M2 hex nut:
[attachment 75463 Untitled.png]
highlighted in the green brackets you can see a channel for the M2 holt, and highlighted by the yellow dots you can see a capture point for the M2 hex-nut. the belt grabbers are *separate* parts, such that (a) you can adjust them simply and easily if the belt happens to be a different thickness and (b) if they print incorrectly you're not wasting 2 hours and 3 metres of PLA and (c) there's a large gap such that the printer is far more likely to be accurate on the first go.
the second thing i found that was problematic about these designs is the cable-tie points. basically there's an assumption that the gcode-generation software used (or the printer itself) isn't going to leave bits of plastic inside the channels.. see arrows in green:
[attachment 75464 Untitled2.png]
basically on this redesign what i've done is make the channels on the *outside* of the bearing-holders, not the inside. there's a couple of places which are bridged over, but from different angles you can definitely see clear air.
the reason why it's problematic to have totally-enclosed (curved) channels is illustrated by what i had to do when printing out the original parts. the cable-ties wouldn't go through: they were totally jammed. of course, normally, i would use an xacto-knife and jeweller's screwdriver.... but these are *curved* channels. so instead, i got a metal keyring, bent it open a bit, got a fine key-file, sharpened one end, and began jabbing and scraping around until bits started falling out.
TWO HOURS LATER i had managed to get all twelve cable-ties into the X-End, Y-End and Carriage parts.
all it takes is to have open channels like on the redesign.
anyway - if anyone would like to generate the STL files you can do so by downloading the source code with git. you'll need python2 and a recent version of openscad [these programs are entirely libre]. if anyone would like me to generate the STL files on their behalf, drop me a line.
Re: FuseBox ~$300 CoreXY Printer March 29, 2016 01:40PM |
pen25
yea i didnt have any issues with the channels. and i took and measured belts from 4 different printers and they all measured 1.7 to 1.9mm thick and i was able to fit them into the 1.8mm gap. i will say though that the 1.7mm thick belt went in too easy so id probably use a bit of hotglue to secure the belt. and the 1.9mm belt took some coaxing.
BTW i also uploaded the file to thingiverse allong with the updated carriage.
Re: FuseBox ~$300 CoreXY Printer March 29, 2016 08:00PM |
lkcl
pen25
yeah that doesn't sound very sensible - like i said, these parts are not designed with engineering tolerances in mind, i've encountered a couple other instances of parts like that. the reason i say it doesn't sound very sensible is, what happens when the belt, which will vibrate, hit the X-Ends and Idler edges, and, under friction, eventually wear out - perhaps rather quickly? then you'd be looking at stripping out that belt, including possibly breaking the carriage if the belt is attached firmly by the glue - now you're looking at a major overhaul, yeah?
with the redesigned carriage at least the tolerances in the belt are taken up by the screws as they push in between the main carriage and the bolt-holders...
yay! could i ask you a favour, drop STL files in there as well? i've always found it easier to just download STL files (which go straight into all the gcode-generation software), i'm sure other people would too.
Re: FuseBox ~$300 CoreXY Printer April 06, 2016 01:41AM |
Re: FuseBox ~$300 CoreXY Printer April 06, 2016 04:18AM |
pen25
i have updated my BOM to include a few more things i have purchased. I am still under 400 USD but when i order some corner brackets i will be under 425. this isnt including a raspberry pi 3 for octoprint as it isnt needed. and i am thinking the L and t brackets can be left off as right now i am not seeing them doing much
Re: FuseBox ~$300 CoreXY Printer April 06, 2016 02:09PM |
lkcl
git clone [hands.com]\~lkcl//foldable3dsandwich200 Cloning into 'foldable3dsandwich200'... fatal: repository 'http://hands.com/~lkcl//foldable3dsandwich200/' not found
Re: FuseBox ~$300 CoreXY Printer April 06, 2016 02:31PM |
Re: FuseBox ~$300 CoreXY Printer April 07, 2016 01:24PM |
Re: FuseBox ~$300 CoreXY Printer April 07, 2016 03:27PM |
phord
@lkcl Thanks! That works. Also explains why the folder looked empty on the web interface.
I'm interested in your extruder you ended up with because I'm also using 3mm filament. You're right that the simple FuseBox extruder doesn't work for it at all. :-(
This is my first bowden extruder so I'm a newb here. I was hoping your redesign would include a useful extruder for 3mm, but it looks like you had one or bought one somewhere. Back to the drawing board for me, then. I can redesign the fb-extruder, but if I'm going that far I might just start with this one by schlotzz instead. At least it's already in OpenSCAD, it has a 3mm option and it has plenty of remixed versions including some NinjaFlex-capable mods. But I'm open to suggestions.
Re: FuseBox ~$300 CoreXY Printer April 07, 2016 06:17PM |
phord
AX
Schlotzz's extruder works really well, it's what I run on the FB2020 combined with an E3D HobbGoblin drive gear.
Re: FuseBox ~$300 CoreXY Printer April 07, 2016 06:49PM |
lkcl
AX
[e3d-online.com] i assume? ok so it's as effective-gearing as a MK8. cool. that's great to hear that people are getting along well with schlotzz's extruder - questions for you though:
- are you using 3mm filament
- what nozzle sizes do you use
- what's the rating on the motors that you've got
- what micro-stepping setting do you use
- and what max current have you set?
all these things i've found are critically linked to what kind of pressure you're likely to see. i have 3mm filament, i *did* have a 0.3mm nozzle (swapped it out for a 0.4), i've set 1/4 micro-stepping, 1.1A max current (at the moment), and 84oz-in NEMA17's... i was *still* getting skipping with two different direct-drive extruders that i tried.
Re: FuseBox ~$300 CoreXY Printer April 07, 2016 07:17PM |
Ax
That's the one, was bought by accident, was left in the basket pricing things up along with a spare Lite6, so I thought I'd use it xDQuote
lkcl
AX
I use 1.75mm as it's what the rest of my printers use, it doesn't really make sense for me to use 3mm due to that.
I stick with a stock 0.4mm nozzle on the E3D Lite6, the extruder motor is a 40Ncm ( I've no idea what the Imperial value is, I'm in the UK so I work in metric) running at 1/16 microstepping and as for the current, I've not really measured it, I've set the pot to where it extrudes well and left it, the extruder driver is a A4988, the rest are DRV8825s, I just got lazy when swapping out to the 8825s not wanting to do a full extruder recalibration.
