FuseBox ~$300 CoreXY Printer
Posted by AlexY
Re: FuseBox ~$300 CoreXY Printer
May 24, 2016 11:37AM
Finished my build, all I need to do is wire it up.
Just some tips if anyone else is about to start. Most have already been mentioned:
1) Put the axes together first! If you build the frame first, and you find out your z or y axis is too long/short, you're in for some taking apart.
2) I followed someones BOM and got the i3 rods for cheap and was thinking I was going to cut them to size myself. Well I didn't have the proper equipment and getting them cut was a huge pain. if you don't have the proper tools, buy them cut to size!
3) Buy motors with full cables! I bought some motors from ebay with cables about 5cm long. Don't really want to crimp 24 wires(I'm building 2 fuseboxes) and it turns out, finding these cables online and local to the USA for a decent price is a nightmare. If you live in EU or UK e3d sells them, but the websites I've found run around $5 per cable and most ship from China. Too long a wait for me.
Will post pics when I've finished the wiring. Working on a redesign of the carriage to incorporate the heatsink fan also.
Edited 1 time(s). Last edit at 05/24/2016 02:04PM by widespreaddeadhead.
May 24, 2016 01:14PM
The other thing the carriage could desperately use is improved print cooling. Half of the 40mm fan is not really enough.
May 24, 2016 02:02PM
godefroi
Someone posted a remix on thingiverse for a blower fan attachment, might work well.
May 24, 2016 03:32PM
widespreaddeadhead
godefroi
You might be referring to this one, just stumbled on it earlier today: [www.thingiverse.com]
I thought a link/image could help.
Edited 1 time(s). Last edit at 05/24/2016 03:32PM by realthor.
RepRap Lander concept on Concept Forge
RepRap Lander concept on RepRap Forums
My Things, mostly experimental stuff
May 24, 2016 04:33PM
realthor
in the notes on the mendel90, written by nophead, one of the most competent and intelligent engineers who has ever turned to 3d printing, nophead describes how and why he designed the hotend cooling system for the mendel90. the key thing that struck me and has stayed with me ever since is that the open-torus-shape that he created was *specifically* designed to create a consistent and uniform airflow around the entire hotend. the reasons why this is important should be fairly obvious: (1) ensure that the heat distribution in the hotend heater block is not disrupted and (2) ensure that the hot air around the part is uniformly moved away from the plastic.
the design above, by complete contrast, specifically states that the airflow is so focussed and so high (in one and only one direction) that it can actually cause non-uniform heat distribution in the aluminium block and can cause a thermal runaway.
bottom line: if you use this blower-fan design you are pretty much guaranteed to run into difficulties, affecting the quality of parts as well as risk destroying expensive parts of your printer.
can i suggest instead obtaining one or two of the tiny 25mm fans that alfa-tech3d has just got in stock. as an interim measure i am currently suspending one of those (with no airflow redirection) to point at a nozzle and, whilst not perfect, it is at least functional and provides considerable airflow.
May 24, 2016 06:13PM
lkcl
[www.desiquintans.com]
May 24, 2016 06:24PM
phord
thumbs up pretty nice analysis...
Edited 1 time(s). Last edit at 05/24/2016 06:57PM by realthor.
May 24, 2016 06:52PM
phord
lkcl
quoted from that page: "Most of the combinations for the Surround shroud type are blacked-out because the other shrouds would not physically fit around it. "
which makes no sense as a sentence so you have to look further down, but we can concldue that the person carrying out the test - who was *not* nophead (one of the most highly respected and competent 3d design engineers that we know of) - specifically *EXCLUDED* the *EXACT* type of cooling system that i *SPECIFICALLY* mentioned was the one that nophead *SPECIFICALLY* designed because of his expertise, experience and design knowledge in 3D printing.
looking at the part that the individual used in the tests, the "shroud" type is also specifically NOT the one that was designed by nophead, it is in fact designed by some other individual whom i do not recognise. their surround shroud part is smaller, and takes only a 40mm fan.
nophead's mendel90 design takes i believe it's a 60mm fan, and is a much larger part, and i would trust nophead's design expertise to analyse the airflow correctly, much more than i would trust a random part found on thingiverse.
so, a useful link in carrying out a part-analysis, phord, but not one that specifically bears any relation to the quoting of the sentence that you included (which came with no other context or sentences and we cannot guess what you intended to say). if you had simply provided the link *without* quoting me we would be able to say "thank you for providing the information".
what did you intend for us to deduce from the quoting, could you elaborate?
June 07, 2016 09:45AM
Finally have mr printer built and pretty much wired. Just wondering what gauge wire I should use from the PSU to the RAMPS, and from the RAMPS to the heated bed. Thanks!
June 07, 2016 10:57AM
I used 14 gauge solid from the PSU, and 16 gauge speaker wire to the bed. I think. Might have been 12 and 14. Heavier is better, you're dealing with a lot of current.
June 07, 2016 11:48AM
Is it ok to use solid wire? My i3 uses braided from PSU, so I just want to double check. Also,anyone familiar with rep. firmware tell me if it's pretty easy to config like marlin? I need to add a heated bed and change the stock temps for the extruder from the provided firmware.
June 07, 2016 12:13PM
From Adafruit Ask an Educator
Some advantages of solid core wire:
  • Cheaper to produce
  • More compact diameter for the same current carrying capability as stranded
  • Less likely to fail due to corrosion
Disadvantages of solid core wire:
  • Typically only available in small gauges
  • Continuous flexing or vibration will cause the wire to fatigue and break
Some advantages of stranded wire:
  • Very flexible and withstands a greater amount of flexing and vibration
  • Easier to rout
Disadvantages of stranded wire:
  • Diameter is larger for the same carrying capability as solid
  • More costly to produce as the manufacturing process is more complex
  • More likely to fail due to corrosion from capillary action & a high surface area
Either should work just fine, although I prefer stranded wire over solid wire for most things (but I do use wire ferrules on the termination points of my stranded wire)
Edited 1 time(s). Last edit at 06/07/2016 12:14PM by PDBeal.
June 07, 2016 02:02PM
Thanks!
June 07, 2016 02:07PM
Stranded is a must for the bed, as it's always moving. For the PSU, solid is better.
June 08, 2016 08:36AM
Thanks all! Getting the wires today and will post pics soon!
June 10, 2016 09:13PM
godefroi
Yeah, when I designed the printer I used the 40mm fan that came with my old Two Up, which was powerful enough to cool the hotend by a few degrees when at maximum speed. The replacement fan I got after it broke is much less powerful so the printer doesn't cool as well as it should now.
The cooling duct on the new printer I'm working on will use the full flow of a 30mm fan, which should improve things a bit. It also has room for a second cooling fan mounted in front of the E3D Chimera hotend I'll be using.
June 10, 2016 09:35PM
I think the blower setup available on Thingiverse has the potential to improve things, but the fan nozzle I think could use some more work.
Ax
June 12, 2016 07:45PM
As a note, it may be a bit more printing than you want to do, but if you reprint the carriers, carriage and layer fan assembly from the FB2020, it will all just drop into the Fusebox.
Ax
June 12, 2016 07:53PM
godefroi
Current Carrying-wise, there's actually no difference from using Solid or Stranded for DC current. Personally I prefer good quality Silicone sheathed RC wire. 14 AWG PSU > Board, 16AWG Board > Bed. Alllows for easy routing due to the highly flexible nature of the wire.
June 13, 2016 09:53AM
Thanks everyone, great information as usual. I have the wires on order for tomorrow, but now I/m a little confused as to which motor is the x and y when I go to wire them to the board, I'm new to coreXY setups.
June 13, 2016 12:49PM
They're both X and Y. Doesn't really matter which goes where. Just make sure your motors move in the correct direction when instructed (I did this from pronterface), and if they don't, reverse a connector or the other until they do. Remember, the X limit switch is MAX, not MIN.
June 13, 2016 12:52PM
Ax
I'm really quite partial to the centrifugal setup, because of the higher pressure; it should perform better with ducting.
July 19, 2016 11:43AM
Someone willing to help me get the config.h file worked out? I've never used repetier firmware, but I've used Marlin so it's not a total mystery. I want to make sure I have the esteps for the leadscrew correct, to have the heated bed enabled, and to have the correct temps set for my hotend(e3d volcano).
I see #define ZAXIS_STEPS_PER_MM 2560 and this is what I would edit for the lead screws correct?
I see #define HAVE_HEATED_BED 0 and I would change 0 to 1 for the heated bed to be enabled?
I see these under heated bed settings also
#define MIN_EXTRUDER_TEMP 150
#define MAXTEMP 250
#define MIN_DEFECT_TEMPERATURE 0
#define MAX_DEFECT_TEMPERATURE 290
I would edit these for the hotend temp?
Do I need to change any settings to get the full graphics controller to work also?
Thanks!
Edited 1 time(s). Last edit at 07/19/2016 11:45AM by widespreaddeadhead.
July 19, 2016 12:10PM
Use [www.repetier.com] to make the configuration.h. It makes it easy to setup Repetier.
July 19, 2016 01:11PM
stephenrc
Great tool, thanks!
Should I enable watchdog?
July 19, 2016 03:26PM
widespreaddeadhead
stephenrc
Great tool, thanks!
Yes.
July 20, 2016 08:52AM
Uploaded my modified firmware, but nothing moves. The full graphics controller doesn't light up, so I connected through repetier-host and when I home the motors they just hum, the hotend and heat bed are off but say they are at printing temps, and when I do turn them on they don't heat up. Any clues?
I still need to adjust the pots for the motors, but having none of them move worried me a bit. I'll double check I have the right thermistor selected in the firmware again. No idea about the graphics controller.
Thanks!
July 20, 2016 02:16PM
widespreaddeadhead
Thanks!
It sounds like you may be missing one of your voltages. 12 volts or even 5 volts, though I'd guess first at 5 volts is missing. I believe there are some jumpers on RAMPS for the 5 volt section.
-os3dp
July 21, 2016 09:35PM
os3dp
-os3dp
How would I check that? The arduino has power and the endstops light up.
Edited 1 time(s). Last edit at 07/21/2016 09:49PM by widespreaddeadhead.
July 21, 2016 10:39PM
Ok, I swapped the cables on the back of the graphics display and that worked, so the display now works. Applied the correct thermistors, and now the display says bed thermistor is defective, and still says the hotend is heated even though it's off. Motors still don't move.
Here is the RH log from start up, in case this helps:
21:35:56.372 : OpenGL renderer:Intel(R) HD Graphics 4000
21:35:56.372 : Using fast VBOs for rendering is possible
21:36:59.161 : Printer reset detected - initalizing
21:36:59.168 : start
21:36:59.174 : Transformation matrix: 1.000000 0.000000 0.000000 0.000000 1.000000 0.000000 0.000000 0.000000 1.000000
21:36:59.363 : N1 M110*34
21:36:59.363 : N2 M115*36
21:36:59.363 : N4 M114*35
21:36:59.363 : N5 M111 S6*98
21:37:01.832 : Free RAM:3785
21:37:01.838 : SelectExtruder:0
21:37:01.845 : N6 T0*60
21:37:01.845 : N7 M20*22
21:37:01.859 : FIRMWARE_NAME:Repetier_0.92.9 FIRMWARE_URL:[github.com] PROTOCOL_VERSION:1.0 MACHINE_TYPE:Core_XY EXTRUDER_COUNT:1 REPETIER_PROTOCOL:3
21:37:01.860 : Printed filament:0.00m Printing time:0 days 0 hours 0 min
21:37:01.860 : PrinterMode:FFF
21:37:01.860 : N8 M80*19
21:37:01.939 : X:0.00 Y:0.00 Z:0.000 E:0.0000
21:37:01.939 : DebugLevel:6
21:37:01.940 : SelectExtruder:0
21:37:01.940 : Begin file list
21:37:01.942 : N10 M220 S100*80
21:37:01.942 : N11 M221 S100*80
21:37:01.944 : End file list
21:37:02.025 : N12 M111 S6*84
21:37:02.027 : N13 T0*8
21:37:02.034 : DebugLevel:6
21:37:02.037 : SelectExtruder:0
21:37:02.934 : Error:Heated bed exceeded max temperature!
21:37:02.938 : DebugLevel:14
21:37:02.938 : Other:: working
21:37:02.943 : heated bed: working marked defect
21:37:02.946 : Errortongue sticking out smileyrinter set into dry run mode until restart!
21:37:02.950 : Disabling all heaters due to detected sensor defect.
21:37:02.950 : DebugLevel:14
21:37:03.036 : Error:Heated bed exceeded max temperature!
21:37:03.134 : Error:Heated bed exceeded max temperature!
Edited 1 time(s). Last edit at 07/21/2016 10:40PM by widespreaddeadhead.
