Best Z-axis configuration? November 16, 2015 04:56PM |
Re: Best Z-axis configuration? November 16, 2015 08:48PM |
Re: Best Z-axis configuration? November 17, 2015 04:31AM |
the_digital_dentist
I think three leadscrews driven by a belt is a good idea, but I could probably live with two on opposite ends of the bed, not cantilevered. There are no forces working to tip the bed when supported by two screws, so it should be OK. Three provides even better stability. Four is going to cause problems.
Don't use threaded rods for linear motion unless you're making something in which the sloppiness they produce is OK. Usually it is not OK.
I like linear guides. They are as good or better than bearings have to be for 3D printing.
Re: Best Z-axis configuration? November 17, 2015 05:48AM |
Re: Best Z-axis configuration? November 17, 2015 07:08AM |
filipeCampos
The bed size make a very big impact in the solution to use and this is something your are not considering.
My corexy was an little bed of 20cm x 20cm. I´m using a very simple solution of one 8mm leadscrew and two 12mm rods with two 12mm bearings for each rod. For you is a big NO NO and i do not agree. I have this solution implemented and it simply work. The bed is always very precise and move fast with an constant speed. For bigger beds like 40x40 you can add an 3º rod in the opposite side or simply an second motor with an 8mm leadscrew.
You are trying to solve your problem adding more rods, motors or changing the linear motion system, this is one way to solve this but i think there are simply and cheaper ways to do the same.
Some suggestions:
-You are using 8mm rods, i think you need to go 12m minimum.
- change the flexible coupler to rigid coupler. I have used flexible one before and for me it was problematic. I was changed to an rigid coupler and it give me better result, less vibration and better/constant movement.
- And the most important suggestion is to not use only one bearing in each rods, this will not give enough horizontal support. The bearings of each rods must have a good distance between them.
For me i only consider adding an second motor in case the first motor do not have enough force to push the bed up. Adding an second motor or an second leadscrew can be problematic if they not move the bed in perfect synchronization.
Re: Best Z-axis configuration? November 17, 2015 08:13AM |
Edvardas
I am still unsure if leadscrews are the best solutions. It seems that many are fighting Z banding and I do not want to spend 100 euros on the leadscrews that are not going to give an optimal performance. Using belts to directly drive Z axis seems like a best performing solutions but I am lost in step size/microspetting/holding torque and so on. 0.2mm layer heights are actually fine by me so resolution should not be problem.
Re: Best Z-axis configuration? November 17, 2015 08:52AM |
Re: Best Z-axis configuration? November 17, 2015 11:00AM |
the_digital_dentist
Edvardas
When people switch from threaded rods to lead screws, if they are still having Z banding problems, it isn't because of the screws. It's more likely that the coupler isn't centering the lead screw over the motor shaft combined with using flexible, end-supported guide rails and maybe a flexible printer frame. The motor end of the screw (at least) should have it's own bearing. That keeps it centered and makes the alignment with the motor shaft less critical. You should be able to print a motor mount that has a bearing for the lead screw and room to add a shaft coupler for the motor. Z axis motors generally run pretty cool so a printed mount should hold up just fine.
Re: Best Z-axis configuration? November 17, 2015 11:17AM |
filipeCampos
You already have build an z axis, but is not working great... I think before trying to rebuild the Z axis from scratch you can try to fix it first.
You are using 4 rods and 2 threaded rods, in theory it should be an very solid solution.
Why is not working great? Can you tell in more details the problems you having?
Re: Best Z-axis configuration? November 17, 2015 11:25AM |
Re: Best Z-axis configuration? November 17, 2015 11:29AM |
Re: Best Z-axis configuration? November 17, 2015 11:49AM |
Edvardas
So I was researching on the motor stepping/microstepping and it seems that I could base my design on this one [www.thingiverse.com] If I use GT2 20T pulley and a 200 steps per revolution stepper. I would come up with a Z axis resolution of 0.2mm per one full step which is what I use most of the time (anyone care to check if my step/resolution math is right?). Later I could get a 400 steps per revolution stepper if I would need 0.1mm resolution per full step. I could design the brackets and see how I like it with the rest of the 8mm smooth rods. If it works good then I could upgrade rods to fully supported rods or linear guides.
Re: Best Z-axis configuration? November 17, 2015 12:04PM |
LarsK
Your math is OK but it doesn't work like that. To get consistent print with 0.2mm step you need to have a higher resolution then just 0.2. I don't remember the multiplier (but 16 or 32 microstepping will be fine) . On the proposed design you will most likely have problems driving the motor if you don't get at least the DRV8825 (1.5A instead of 1A). The DRV8825 will also give you more microstepping (32 against 16).
Re: Best Z-axis configuration? November 17, 2015 12:43PM |
Edvardas
LarsK
I have read that at full steps motor has a higher holding torque (which is important in this instance). If a motor works on lets say 16 microstepps does it still have a full step every 16 micro steps where it has that higher holding torque? Or does it work on microsteps only?
I can already see that green A4988 seems weaker than black version I have used before.
Re: Best Z-axis configuration? November 17, 2015 12:49PM |
Re: Best Z-axis configuration? November 17, 2015 03:38PM |
LarsK
There are absolutely no problems in a cantilevered design (!) - Not many years ago most mills (for metal working) was with a cantilevered bed.
Re: Best Z-axis configuration? November 17, 2015 03:49PM |
Re: Best Z-axis configuration? November 17, 2015 05:10PM |
LarsK
First - Holding torque is not the problem - The problem is moving the bed up without skipping steps (pre-print). If you have a "normal" setup then you have a Z-max probe. So the printer sends the bed to this and then move up your specified Z-height. If it skips steps when moving up then it will stop in the wrong height and your print will not touch the bed...
Next, when we talk about reduced torque for microstepping, we talk about that particular microstep. When you have microstepping you have that "any load torque will result in a “magnetic backlash”, displacing the rotor from the intended position until sufficient torque is generated."
That means, if you are dividing your steps into 32 microsteps and you want to stop the printer at 17/32 of a step, then the torque available to hold it at that particular fraction of a step is roughly 5% of the rated torque but the further away you drive your shaft from the intended 17/32 the more holding torque it generates.
This is true until you actually reach the full step and the full holding torque. The stepper missing a full step is a different thing and permanent event that the stepper does not recover from if you removed the load (does not return but finds 17/32 one step back instead).
I learned that and took the quote from reading : [www.micromo.com] .
Re: Best Z-axis configuration? November 18, 2015 06:51AM |
Edvardas
LarsK
I do not have a Z-max. I use an endstop at Z0 (zero coordinate) so only Z-min is present. Before every print I simply home all the axis. Any earlier missed steps does not mater.
I am now thinking that under the current setup there is no way to make sure that a motor stops at full step then bed travels to Z0 coordinate. This means that before powering the printer bed rests at the bottom of the printer. Then I home axis bed travels up and if a distance to Z0 is for example 200.3 mm the bed will stop at 16th or 17th microstep (if 32 microsteps stepping is considered) and will work on this microstep throughout the whole print. If distance is 200.2mm then the motor would work at full step for the rest of the print.
Re: Best Z-axis configuration? November 18, 2015 10:22AM |
Re: Best Z-axis configuration? November 19, 2015 05:33AM |
Re: Best Z-axis configuration? November 19, 2015 06:15AM |
Re: Best Z-axis configuration? November 19, 2015 06:54AM |
Re: Best Z-axis configuration? November 19, 2015 07:45AM |
J-Max
To me, the design of AndreasL is just a start.
I printed one for dev purpose, and there's several things that can be improved.
First, some parts are too thin. Especialy supports and the ends of the arms.
The supports have only two screws, and that's not enough. You need at last 3 in triangle.
The worst point IMHO is resolution, you only get 0.2mm at full step.
That's why I want to install a belt reduction 4:1.
With a belt reduction the Z resolution will be under 0.05m.
++JM
Re: Best Z-axis configuration? November 19, 2015 07:57AM |
realthor
The original smartrap has a different size (larger) upper pulley that acts as a reduction as I read somewhere. Can't that solution be applied for AndreasL's solution as well?
I realy like the design of AndreasL.
I was impressed while seeing it working, each part alone looks weak,
you expect it unstable but the Z plate squares and hold all together.
It's cheap, it works pretty well and it's fast. I love the belt holders : quick, easy and efficient.
After a lot of cycles, no belts moved out.
That's what our fablab install on our SmartRapCore printers. One is 300x200mm.
There's no glory wto use expensive and complicated stuff like ball screw, rock solid guides and structure, and cosly machinist measuting tools to make all work properly.
On my CNC, the Z ensemble itself weight 35kg (77lbs) cost me more than $2000 and believe me that baby is tuned within 0.02 mm (0.001") !
What realy impress me are simple and unexpensive things that works fine with a belt few bearings and just a speed square for setup.
Re: Best Z-axis configuration? November 19, 2015 08:01AM |
filipeCampos
Only speaking of the mechanism to move the bed and not the bed structure or linear motion. AndreasL is an interesting concept but i still think the use of lead screw is better.
One lead screw of 40cm has cost me 18€ on ebay and more 2€ for the coupler. If you go to the AndreasL solution it will be really cheaper? You still need to buy the belt, pulley and bearings. The total can be less of 20€.. but it really worth it? You still need to solve to problem of the missing reduction, something you automatically have in an lead screw solution. The belt allow fast speed, but you need this type of speed in the z axis?
I think there is better way to save money...
Re: Best Z-axis configuration? November 19, 2015 08:06AM |
Edvardas
J-Max
I think that 4:1 reduction via pulleys would be complicated to achieve. Better do 2:1 belt reduction (40T and 20T pulleys) and use 400 steps per revolution stepper motor. That would be more compact and easier to source parts.
Re: Best Z-axis configuration? November 19, 2015 08:16AM |
Edvardas
Here is some information on the correct mounting techniques for leadscrews [blog.helixlinear.com] You can mount a single leadscrew according to A technique but to be able to use two screws driven off a single motor one would need use technique B. For this one would need a high quality perfectly straight lead screw otherwise screw would transmit any irreguliarities to the bed and to the print itself.
Re: Best Z-axis configuration? November 19, 2015 08:25AM |
J-Max
And, there will be no issue with bed weight and it will hold upscaled build volumes.
I want to use better pulley and idler pulleys too,608zz is a standard, but smaller diameters are better and belt teeth rund better on proper pulleys.
++JM
Re: Best Z-axis configuration? November 19, 2015 08:27AM |
LarsK
Edvardas
Excellent page. Been looking for something like that. Thank you.
