Re: Best Z-axis configuration? April 25, 2016 08:30PM |
robkar
I guess your biggest issue would be that the scissor lifts Z motion doesn't have a linear relationship to the rotation of the motor..
Re: Best Z-axis configuration? April 26, 2016 04:10AM |
Re: Best Z-axis configuration? April 26, 2016 08:56AM |
Re: Best Z-axis configuration? April 26, 2016 09:58AM |
realthor
The perfect backlash-free gearbox that I'd try with this material or nylon is a re-design of the harmonic hyperdrive that OskarPuzzle youtube user presented quite recently. Here's an image of the thing:
Re: Best Z-axis configuration? April 26, 2016 09:59AM |
realthor
What weight do you want on the bed that a scissor lift is needed?
Re: Best Z-axis configuration? April 26, 2016 10:09AM |
lkcl
realthor
totally cool - it's actually a belt-drive, where the "belt" is also plastic but is thin enough to be flexible. awesome design.
Re: Best Z-axis configuration? April 26, 2016 11:44AM |
Edvardas
So what are your ideas?
Re: Best Z-axis configuration? April 26, 2016 12:45PM |
realthor
Re: Best Z-axis configuration? April 26, 2016 02:47PM |
Re: Best Z-axis configuration? April 27, 2016 01:26AM |
realthor
If this was machined or laser-cut why would it underperform compared to normal geared steppers? Is it plastic parts that you are talking against or 3d printed parts specifically? If the same materials are considered I see this outperform normal gears.
Re: Best Z-axis configuration? April 27, 2016 01:52AM |
robkar
Re: Best Z-axis configuration? November 13, 2016 12:36AM |
dc42
Adding motion support to RepRapFirmware for scissor lift would be easy. The more challenging part is calibration. The firmware would need to know the exact geometry of the scissor when the homing switch is triggered, because any error would result in non-linear drive.
Edvardas
Allright So I am actually getting better at taking pictures of these small layers. Here is a comparison against aluminium framed prusa i3 print at the same 0.4mm layer height. As you can see belt z-axis print on the left is way more even. And my prusa actually makes nice prints at 0.2mm layer height.
Re: Best Z-axis configuration? November 13, 2016 02:46AM |
Re: Best Z-axis configuration? December 08, 2016 05:10AM |
Re: Best Z-axis configuration? December 08, 2016 07:47AM |
Re: Best Z-axis configuration? December 08, 2016 01:07PM |
Re: Best Z-axis configuration? December 19, 2016 07:53AM |
Re: Best Z-axis configuration? December 19, 2016 12:44PM |
Re: Best Z-axis configuration? December 19, 2016 12:59PM |
Re: Best Z-axis configuration? June 19, 2018 07:08AM |
Re: Best Z-axis configuration? June 19, 2018 07:19AM |
Re: Best Z-axis configuration? June 19, 2018 07:35AM |
Re: Best Z-axis configuration? June 19, 2018 02:03PM |
