Re: Best Z-axis configuration? December 08, 2015 12:28AM |
Re: Best Z-axis configuration? December 08, 2015 02:45AM |
Re: Best Z-axis configuration? January 05, 2016 10:31AM |
Re: Best Z-axis configuration? January 10, 2016 07:49PM |
Re: Best Z-axis configuration? January 11, 2016 10:45AM |
Re: Best Z-axis configuration? February 25, 2016 12:03PM |
Re: Best Z-axis configuration? February 25, 2016 03:05PM |
Re: Best Z-axis configuration? February 26, 2016 01:54AM |
Re: Best Z-axis configuration? February 26, 2016 06:22AM |
Re: Best Z-axis configuration? February 26, 2016 05:02PM |
NathanaelXYZ
Couldn't a cantilevered bed be "enhanced" by supporting more than one side of the bed on a single lead screw? Pulleys and cable could be used to transfer the load from one point to another, as in this diagram:
[attachment 69484 compound_z_scaled.jpg]
I am currently gathering materials to build a printer using this system for z; I will report back with results.
Re: Best Z-axis configuration? February 27, 2016 11:07AM |
Re: Best Z-axis configuration? February 27, 2016 11:26AM |
Re: Best Z-axis configuration? February 27, 2016 12:54PM |
Re: Best Z-axis configuration? February 27, 2016 01:48PM |
Re: Best Z-axis configuration? February 27, 2016 02:37PM |
Re: Best Z-axis configuration? February 27, 2016 03:21PM |
Re: Best Z-axis configuration? February 27, 2016 03:34PM |
Re: Best Z-axis configuration? February 27, 2016 05:04PM |
Re: Best Z-axis configuration? February 27, 2016 06:00PM |
Re: Best Z-axis configuration? February 27, 2016 06:23PM |
Edvardas
After you put those extremely long belts on XY axis you become quite positive about them having zero backlash.
Edvardas
My Z-axis belts are shorter than XY ones.
Edvardas
And I was printing two of these cubes at the time (in order to let the plastic cool down on the other one). I was using a z-lift of 0.2mm; this means that the bed was going up and down multiple of times during the print. There can not be a better way to test for backlash not being a problem.
Re: Best Z-axis configuration? March 08, 2016 02:19AM |
Re: Best Z-axis configuration? March 08, 2016 02:42AM |
Re: Best Z-axis configuration? March 08, 2016 06:34AM |
Re: Best Z-axis configuration? March 08, 2016 08:18AM |
Re: Best Z-axis configuration? March 08, 2016 08:22AM |
Re: Best Z-axis configuration? March 08, 2016 08:35AM |
Re: Best Z-axis configuration? March 08, 2016 09:51AM |
Re: Best Z-axis configuration? March 08, 2016 10:01AM |
Edvardas
I would not mount smooth rods into pre-drilled holes. You will never get them lined up that way.
2020 is very easy to drill. I use a hand drill myself. Holes are there only to put a hex key though so they do not need any accuracy.
Re: Best Z-axis configuration? April 25, 2016 07:30AM |
Re: Best Z-axis configuration? April 25, 2016 10:36AM |
ThistleDown
Forgive me if this is a dumb idea, but would a lead screw driven scissor lift make a good Z-axis? Assuming four linear guides for stability, and the scissor under the center of the platform. It would be more weight, and possibly more work in basic construction than a belt system, but it would center the drive force under the center of the plate instead of at the edge. Would the scissor introduce imprecision relative to a vertical lead screw or belt?
