Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 06:35AM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 12:34PM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 03:53PM |
grat
Take a section of metal tubing slightly larger in diameter than your bolt and slightly shorter in length than the inside dimensions of your square tubing, thread the outside ends, attach bolts, slide into place, drop bolt through.
For ease of positioning, wrap some solid core wire around the middle of the tube while you're positioning it, and pull the wire loose once the bolt's through.
Or just spend the extra few dollars on some 2020 extrusions and either some cube corners or some cast aluminum 90 degree angles.
lkcl
oo. duh. yes. sorry, didn't realise the significance of this earlier - yes, that would work great.Quote
realthor
On the other hand I have just noticed that an M10 Nut is 16mm between flats ... so a printed part with an M10 Nut space ....interesting.
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 04:49PM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 05:01PM |
grat
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 05:02PM |
...Thanks for setting us straight
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 05:17PM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 06:07PM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 28, 2016 07:21PM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 29, 2016 03:26AM |
cozmicray
oops --- your across the pond ---- drill press 10000 euro
) . + Frequent mover to rentals as of late (with job) ... home is far away.
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions April 29, 2016 06:35PM |
realthor
BTW: you're so spoiled over there
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions May 04, 2016 12:57PM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions May 04, 2016 01:01PM |
realthor
[attachment 77270 ScoutCoreXY_IntraTubeConnection.png]
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions May 04, 2016 01:21PM |
lkcl
realthor
yehhhh, niiiice - i like it. no squashing. tubes won't twist. if you can use a bit of square plate with a tapped hole instead, you'd not need a washer, or a nut, which would be a heck of a lot easier. maybe you can find some biiiig square nuts... or just some big hex nuts.
now why didn't i think of the idea of just going through one side of the extrusion, ehn? oh - use allen-key bolts, so the access hole you drill is smaller.
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions May 04, 2016 05:53PM |
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions May 05, 2016 02:59AM |
realthor
I have also started a Wiki page for SCOUTcorexy here on reprap: http://reprap.org/wiki/SCOUTcorexy.
Re: Coffeetable CoreXY:: new build :: small apartment rep-strap solutions May 14, 2016 10:03AM |
