Re: CoreXY vs Quadrap mechanism December 05, 2015 08:39PM |
realthor
Belts are difficult to use in non-linear devices like the one I linked to because it's difficult to engage a toothed pulley that sits in between to segments of straight line. One would have to insert two additional pulleys that would force the belt go around as many teeth as possible around the large pulley, something like this. Also having such a large pulley like in my design is quite difficult to have it machined. The closest I can think of is glue a belt around it so the other belt has something to engage to.
Re: CoreXY vs Quadrap mechanism December 05, 2015 11:04PM |
realthor
Belts are difficult to use in non-linear devices like the one I linked.
patrickrio
The whole point of the discussion is to bring attention to the "gotchas" of installation - and parallel is the biggest gotcha I see for CoreXY when using linear guides. Maybe it is not that big of a gotcha, but I think it may be the biggest one. Adding lips to a design may not cost much, and pretty much eliminates (or at least reduces substantially) all facets of the problem as it exists in the CoreXY mechanism.
Re: CoreXY vs Quadrap mechanism December 06, 2015 12:36AM |
Re: CoreXY vs Quadrap mechanism December 06, 2015 02:35AM |
the_digital_dentist
Misumi's first sentance says it all: "If you need a quick and easy way to facilitate a linear motion profile, the linear bushing is a great choice, especially if you don’t have high tolerance or accuracy requirements. "
Re: CoreXY vs Quadrap mechanism December 06, 2015 10:15AM |
